homemade cai?
Old 09-05-2001, 07:09 AM
Dave421's Avatar
Default homemade cai?
Has anybody made a custom cold air intake for their 5th gen? I'm wanting to build one for my 94 EX coupe but can't find any info for it anywhere (yes, I searched). I really can't justify spending a couple hundred for buying one when I can build one for 1/3 the $. So, before I begin, does anyone have any info??
(and for flamers, you try going to school while your wife is a teacher supporting you both and have $ left over for mods)
Old 09-05-2001, 11:42 AM
New User
KEVlN's Avatar
Default Re: homemade cai? (Dave421)
I have a friend that did it to his. I know it consist of some PVC piping and getting rid of some pieces from your original intake, but I will see if I can get some more info for you.
Old 09-05-2001, 12:06 PM
jg
jg's Avatar
you didn't search hard enough... I expect a reward for this... http://www.teamdelsol.com/howto/coldair/diycoldair.htm
Jeff
Old 09-06-2001, 07:24 AM
New User
KEVlN's Avatar
Default Re: homemade cai? (jg)
so this procedure works for a 95 civic? How much time should i allow for the procedure?
Old 09-06-2001, 11:12 AM
Dave421's Avatar
Default Re: homemade cai? (Civic95)
Sorry jg but I had seen that one. I was under the impression that a cold air for a del sol would not work for a civic coupe though. Being different motors and different bodies, I was not sure if it would work or not. Is this not the case and this will work for a civic?
Old 09-06-2001, 11:16 AM
MrDX's Avatar
You may be right Dave421.. but the principles are identical. You'd be doing the same just with your plastic intake pipe.
Old 09-06-2001, 11:51 AM
jg
jg's Avatar
Default works fine!
I used Slater's article as guide to build my own for my '94 hatch. It worked fine. This is not an exact science. I would also recommend the piping from JCWhitney. It's cheap (like $20?) and they'll have it to you in a day if you want. If you have the filter, clamps, silicone hose and the piping, anyone can do this in a couple of hours. It's very easy. Just adjust the bends and their respective angles to suit your fitment. Hope this helps.
Jeff
Cannuck 94
16
12-30-2005 11:30 AM
rive22
08-02-2004 05:51 PM
Fidelio25
07-04-2004 09:21 AM
akeldama
12-12-2002 07:59 PM
Alienproject
07-06-2002 02:41 PM
Quick Reply: homemade cai?
