hmm..what do you call this?
Trying to find a gauge pod that would fit in the climate control area like that, I have a 99 civic & my headunit is relocated just as the same spot in that pic. So I have a big open space where my climate control is now. My question is so can you buy a gauge holder seperately like that one? or is it the whole climate control assembly? Also, what would call either of em (im trying to search for em to buy em), thanks..
Re: hmm..what do you call this? (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">you can just get a piece of plastic and drill 2" holes to fit some 52mm guages, then find a way to get that piece of plastic to stick onto the climate control from behind</TD></TR></TABLE>
Easier to buy a radio block off plate from honda. You dont have to figure anything out just cut it!!
Re: (sk8shorty012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 »</TD></TR><TR><TD CLASS="quote">gotcha, so then lastly would you need the rectangular piece I was talking about? Basically the same width as your headunit, but just open space to stick **** in? Then put the plastic piece over that?</TD></TR></TABLE>
Are you ****** retarded? expletive how many times do we have to explain it to you.
Get a ****** plastic peiece and cut it! damn...
Re: (sk8shorty012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 »</TD></TR><TR><TD CLASS="quote">just so you know, all I was asking secondly was if you needed somethin to mount the block off to.</TD></TR></TABLE>
no. you dont.... the block off plate mounts itself in the DIN slot, so its flat and blocked off. then cut the holes in that in order to mount the gauges.
Re: (94hatchling)
Well, so far when Ive searched, all I can find is a double block off plate for the 99-00, but Id like to keep the bottom part of the area (the rectangular piece with space to stick **** below where the radio originally goes), so thats a no go, unless the single block off from 96-98 would work? But I doubt it. Also, I know that I don't need "a block off plate" and can just use a piece of plastic for my app. but where would you guys recommend getting something like that?
Go Tigers!
Re: hmm..what do you call this? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Jesus! That guy has too damn many gauges and crap going on there..</TD></TR></TABLE>
my thoughts exactly. guy probably wears a watch on both wrists.
Re: hmm..what do you call this? (xd69)
You would think that dude could be able to afford some better tuning than an AFC and atleast an Si cluster so he didn;t have to have that retarded *** tach.
Re: (ChadB)
I made my own with ABS plastic.
Measured then did my cuts. Then to keep it on there i used a hot glue gun to keep it to the area and then used a sharpy to paint the glue black.
Metal Typhoon
03-12-2007 03:30 PM
KdiZzLe
11-15-2006 04:58 PM
redline201
28
07-18-2003 01:33 PM
