hmm interchangable, b to d?
Okay so i have a 99 si with a b16a2. A week ago i blew my motor and since im on a budget i just bought a d16y5 today full swap. Im guessing itll fit right into my car since it came out of a 99 hx i think. Well heres my question list:
1) Can i use my b16 ecu on the d16y5?
2) Can i swap over the intake manifold from the b to the d?
3) can i use the lower left mount from the b on the d?
4) will my old b series exhaust bolt up to the d manifold?
5) can i use my old shift linkage from my b series?
thank you
thank you
Re: hmm interchangable, b to d? (kinkyintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkyintegra »</TD></TR><TR><TD CLASS="quote">Okay so i have a 99 si with a b16a2. A week ago i blew my motor and since im on a budget i just bought a d16y5 today full swap. Im guessing itll fit right into my car since it came out of a 99 hx i think. Well heres my question list:
thank you</TD></TR></TABLE>
i dont think any of that will swap over except for maybe 1 and 3...but i dont know for sure...so bump for some good info
1.] yes, but it won't run for ****
2.] no.
3.] dunno, SEARCH.
4.] yes.
5.] no.
you're welcome. oh yeah, all these answers are available by SEARCHING.... so try that out next time
2.] no.
3.] dunno, SEARCH.
4.] yes.
5.] no.
Re: (Kobal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kobal »</TD></TR><TR><TD CLASS="quote">The shift linkage isn't any different from a D to a B. I know, I just did a swap.</TD></TR></TABLE>
all I know about is EG's so I dunno about your EM1, but I'm pretty sure you need a new linkage, as they are required for D to B swaps in EG's and EF's.
Re: (Kobal)
you will need d shift linkage
well alright i got the d series linkage.....so i should get a normal ecu? i can swap out the throttle body from my b16 to the d right? and also i think i need a tps, my b16 will fit right?
throttle body will fit, tps should, as well as other sensors, i believe on mounts only one would be goofy mount on driver side what left lower one you tallking bout??? crash mount??? yes normal ecu would be ebtter especially if you want the hx gas mileage
AlienKrOZ
10-22-2003 08:27 PM
