HKS turbo on civic (EK) B16a, what do i need for reliablilty and power
ok, im looking at a b16a right now looking to see what parts i need to put an HKS turbo on it. Im still learning about turbos and there components so i don't know about which turbo manifold to get for a HKS turbo. Also what kind of pistons to create the most power(reliable power)
Re: HKS turbo on civic (EK) B16a, what do i need for reliablilty and power (eriklxsd)
Id start posting in the Forced Induction forum. Lets see, manifold would need an adapter for what ever type of turbo it is, T3 im assuming. Id say Eagle rods and heads, or just upgrade to JDM Type-R heads is prob the most cost effective. As well as R cams. Get a good head gasket as well, then there is all the other stuff for hooking up a turbo.
Hope this helps a little |
Why not just get a kit that is already together, like ^^^^ said go to the forced induction and read up a little bit, then if you still dont understand make a post, there is alot of information on this site and all you hafta do is look around a little bit and do some searching...
also dont listen to this person sayin you should get r cams etc.. there not the best for boost hint hint |
