High Idle Y8 Mini Me Swap
Ok, I've searched and searched but for some reason I couldn't find anything =\ I just finished my Y8 Mini me swap (ZC Block, Y8 Head) Everything is plugged up, NO CEL's just high idle any ideas?
Could it possibly be one of the hoses from my evap system? I couldn't figure out where the house that went on top of my throttle body on the ZC head so I just plugged it for now Edit: Im using Y8 timing belt, Y8 Plugs, Y8 Wires, Stock Injectors, etc etc i followed a mini me swap i saw on here everything went fine but the idle issue |
Re: High Idle Y8 Mini Me Swap
vacuum leak maybe? spray some carb. cleaner around the intake manifold if it revs up thats the area your leak is in.
Did you check your idle air control valve? Could be set high causing the idle to be abnormal. The helms manual will direct you on how to check/adjust your idle via the IACV.
Originally Posted by em1pusha99
(Post 40060446)
Originally Posted by 96 EX
(Post 40060497)
edit: i just remembered i even replaced the PCV this morning too =\ could it be my timing? |
i just tried the vaccum test and nothing
i noticed that my timing belt is kinda loose, about 1/2 shaft play i tried tightening the tensioner but thats all tight, any ideas? |
find anything yet?
Originally Posted by ajason24
(Post 40061238)
find anything yet?
need inputs! |
How high is the idle? If you cover the top of the throttle body with your hand, can you kill the idling engine?
Originally Posted by RonJ@HT
(Post 40063042)
i wanna say its my timing but im not sure =\ theres some slack on the left side towards the front of the motor |
Pull off the air intake to access and cover the top of the throttle body. Also check whether the throttle cable is adjusted too tightly.
(Post 40063338)
ill try that tomorrow morning after a full nights rest any other possible ideas i could try while im at it? |
have you driven the vehicle/let the vehicle warm up?
on cold mornings my car likes to idle at 1500-1800 and as soon as it warms up it drops down to 600-700 |
Originally Posted by crxtuner0
(Post 40063730)
ttt
so i was playing around again and now i got a new code, its throwing code 14 IACV
But the thing is I have a new IACV so whats the reason for it throwing that? |
ttt
My guess would be either
1. Faulty/Malfunctioning IAC or 2. Possible wiring issue? |
Hey, whatever happened to the high idle issue. I'm having the same problem. The car I bought is having a high idle issue. It's a 93 Honda civic with a mini me swap. As far as what heads I do not know. Also the car redlines at about 5000 rpm's. I've let the car heat warm up and drove for about 10 miles and still has high idle at the end. Also car completely loses memory for radio as well as clock every time I switch the ignition off. Definitely faulty wiring somehow but I'm at a loss. Jumped into a project I knew nothing about. Sorry I know I sound like a noob, which I am but defenitly could use the help.
Found this thread by searching potential problems with mini me swap, high idle is either bad IAC or throttle cable bracket is not correct or a nasty vacuum leak... when doing these swaps.. make sure to clean the throttle body off VERY WELL.
