HID's On a 2000 civic hatch.
I am in the process of getting HID'S for my civic. What kind do you think is the best, post your pics of your HID'S and. What size HID'S should i look for? people have said 9006, of H4. IF you got any info help me out.
Thanks for the posts
Re: HID's On a 2000 civic hatch. (airteck371)
Catz makes a HI/LOW h4 kit for your hatch so you retain both high and low beams. If you want projectors, Id suggest an H1 kit.
Re: HID's On a 2000 civic hatch. (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Catz makes a HI/LOW h4 kit for your hatch so you retain both high and low beams. If you want projectors, Id suggest an H1 kit. </TD></TR></TABLE>When you get an HID kit don't you have to get the plug for your stock wiring, Like if you get headlight bulbs, you gotta get the spec bulbs. don't you have to basically have to do the same thing with HID?
Location: Toronto, Canada currently residing in ATL, GA, USA
Yes H4's for stock headlights. If projectos most likely a H3 application
Re: HID's On a 2000 civic hatch. (Apex i ITR)
if you get a kit, it should come with everything you need, all plugs, ballast, harness, etc. you should stay within the 4300k range, because you get the most light output. i settled for the HELLA H4 4800k high/low kit. there is quite a bit of scatter, but there is nothing i can do because EK headlight housings suck. here are some pictures.
Re: HID's On a 2000 civic hatch. (Airbag Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club »</TD></TR><TR><TD CLASS="quote">if you get a kit, it should come with everything you need, all plugs, ballast, harness, etc. you should stay within the 4300k range, because you get the most light output. i settled for the HELLA H4 4800k high/low kit. there is quite a bit of scatter, but there is nothing i can do because EK headlight housings suck. here are some pictures.
what do you mean by scatter, and where did you get your lights at? and for how much? I know how the HID system works, but i'm not sure what all should be done to do the job right, but then again i'm sure its really simple
</TD></TR></TABLE> I know a little about HID systems and how they work and setting them up , but i'm not sure about all the wattages, and brands that are best? what is scatter? and how do i not have that, it don't sound good? let me know thanks
hey airbag club, are those usdm headlights or ctr lights? what did u do for your corners, are those different bulbs? the only reason for all the questions is because im diggin your setup.
New User
Re: (ntrinsik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrinsik »</TD></TR><TR><TD CLASS="quote">Me and my brother plan to retrofit BMW/Audi projectors when we put HID on the car. </TD></TR></TABLE>
Let's see it when your done...
Personaly I like HID, but it isn't for me. I somehow got a test PIAA h4 bulb that is the crazy light I've ever seen. Everyone stairs when I drive at night. It's bright yellow, but has different colors at every angle, not the blinding color of HID. At some angles I can see blue, purple, green, and white. Always comforted buy the 60watt yellow glow...
Re: (nahledge 7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahledge 7 »</TD></TR><TR><TD CLASS="quote">hey airbag club, are those usdm headlights or ctr lights? what did u do for your corners, are those different bulbs? the only reason for all the questions is because im diggin your setup.</TD></TR></TABLE>
thanks...they are painted USDM headlights, and as for the corner, i just painted the reflector the same color as the housing, so it blends in....illegal, but cops don't know . i also use the stock amber light bulbs.
Re: (Airbag Club)
Your setup is really nice airbag.
Well since we are on the topic of retro fitting.
How about a retrofit of the Q45 Honeycombs
on EK headlights. That would be bad ***.
Re: (w00t!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! »</TD></TR><TR><TD CLASS="quote">
Personaly I like HID, but it isn't for me. I somehow got a test PIAA h4 bulb that is the crazy light I've ever seen. Everyone stairs when I drive at night. It's bright yellow, but has different colors at every angle, not the blinding color of HID. At some angles I can see blue, purple, green, and white. Always comforted buy the 60watt yellow glow... </TD></TR></TABLE>
I got a pair of those bulbs too, I use them for fog's in the Family car.
