hey guys h22 sensor help . finishing up my swap.
i have an 98 h22 and its in a 93 si civic. its wired with the stock harness that was in the car. im running a obd1 p13 ecu. i noticced to sensors that were not pluged in. i need to know where should i pin them in the ecu, or at least the names of the sensors
the 1st pic is on the passanger siide by the feul rail.
and the second is on the driver side on the block of the motor
i have the original prelude harness so i could jack pins off it
or should i run the harness with the obd chang over.
also i dont know what injectors im running caseu i dont see a resistor pack
Modified by djsire at 3:00 AM 3/17/2006
Modified by djsire at 3:01 AM 3/17/2006
hey man can you send me some pics of your swap i am about to do it to my eghatchy? my email is 95hatch@comcast.net or hit my on aim at bluhatch95
Re: (94_HATCH)
no im doing it this weekend. i need to weld a bung on my header. but i do have the sensor. 70 bux form auto zone. i picked up the p13 today for 75 bux
while trying to fix the momo horn, i let the car run so the battery wouldnt go dead. it drank a 3rd of a tank at idle for 45 mins. can wait to get the o2 sensor goin lol.
Re: (djsire)
btw are those stock headers? im new to the h22.. and it is 4 wire.
there is also a 4 wire plug from the stock civic harness running across the driver sidefender. but i dont know if there suppose to go toegether(it doestn reach).
Re: (djsire)
if your motor is 97+ the 4 wire plug should be the crank angle sensor. don't worry about it if you have a obd1 dissy. as for the one in the fender. i have no clue. put up a pic
Re: (laosb904)
swap almost complete. i Have no codes!!!!! went to the junkyard and scored the whole egr setup with the evap sensor for 40 bux. now all i need is the damn iab sensor. the only problem i got is the idle is a lil funky.
