Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   Here's a question - will US odometer swap into JDM cluster? (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/heres-question-will-us-odometer-swap-into-jdm-cluster-951531/)
Brewer 08-07-2004 08:20 AM
Would I be able to swap out the odometer from my US cluster into a JDM cluster? And if so, what is it that determines whether an odometer reads miles or km? Would a JDM cluster with a US odometer still read miles?
Or should I just not worry about it?
Brewer 08-07-2004 08:28 AM
Re: Here's a question - will US odometer swap into JDM cluster? (BrewerHatch)
When I say odometer, I mean the entire assebly behind the guage face.
pdiggitydogg 08-07-2004 08:35 AM
arent the faces reversed? Trip and odo placement I mean.
If thats the case then it couldnt work...I think
Brewer 08-07-2004 08:37 AM
Re: (pdiggitydogg)
Ah, never thought of that...
*Googles for pic*
RICE POLICE SIP 08-07-2004 08:39 AM
Re: (pdiggitydogg)
You should be able too. Not 100% sure but it should work, but I believe the JDM face is kmh. Just do the swap and see what happens... https://honda-tech.com/forums/images/smilies/emthup.gif
Brewer 08-07-2004 08:41 AM
Re: (Split Image Prez)
The speedo needle should be calibrated the same, just the guage face is different. My only concer is the odometer. Will it turn in KM's or miles?
Brewer 08-07-2004 08:57 AM
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">arent the faces reversed? Trip and odo placement I mean.
If thats the case then it couldnt work...I think</TD></TR></TABLE>
http://www.japcarboy.com/images/used...eg6meter_3.JPG
TurboEH2 08-07-2004 09:02 AM
yes itll work and itll read miles. since it has the miles gear in it for the vss. i forgot who did it but someone had the us odometer and the rest eg6 cluster. i believe it was in a honda tuning. ill look a little later. and post pics.
pdiggitydogg 08-07-2004 09:02 AM
maybe that was ek's...I know one of them is reversed. oh well
should work ok then
yep - ek I was right
http://www.imagestation.com/picture/...c/f83928cf.jpg
http://www.chillybanana.com/for_sale...7-9733_IMG.jpg
JDM R 08-07-2004 09:02 AM
Re: (BrewerHatch)
im not sure if i understand your plan here but i think you are going to swap out your entire US speedo/odometer assy into your JDM cluster.... i doubt this will work, its the printed circuit behind the cluster that determines whether the odometer reads in mph or kmh. Also your needle will not be reading mph accurately.
you could swap printed circuits as well as speedos and that would work, but be careful when swappin printed circuit because they are easy to fuck up. i over-torqued the screws https://honda-tech.com/forums/images/smilies/emsad.gif
Brewer 08-07-2004 09:41 PM
Re: (JDM R)
Hmmmmm..
PSU 08-08-2004 03:29 PM
Re: (BrewerHatch)
jason, i asked someone a long time back and they said no
i wanted to do it in my hatch, but they said it wouldnt work
2.0L EK 08-08-2004 04:02 PM
Re: (DxHatchback)
It works fine. You can swap all the gauges out, just did it for my friends broken gas gauge. The only thing you might run into a problem with is the DC2 94-97, and DC2 98-01. You will need to find a matching year for those. https://honda-tech.com/forums/images/smilies/emthup.gif
Member 00841 08-08-2004 04:58 PM
Re: (2.0L EK)
negative
1 st off there are no screws on thye face of the jdm eg6 cluster ,
when there are on the usdm. So how can you change km to mph when it will snap i tried and it cant be done Maby jdm gsr are diffrent but jdm eg will not
2.0L EK 08-08-2004 05:30 PM
Re: (JESUSDREAD)
I'm pretty sure everyone is talking about swapping out the entire gauge not just the face. Swapping out the face would make no sense, the MPH and KPH are in completely different locations
Member 00841 08-08-2004 05:37 PM
Re: (2.0L EK)
if you want a black guage in the middle go for it
infact you gonna have to use your usdm cluster housing & switch every part (meaning)remove pins w fork and use jdm faces w usdm backing in side a usdm cluster and cut where your milage will fit !
id just rather roll in km and w a srs light attached!
2.0L EK 08-08-2004 06:08 PM
Re: (JESUSDREAD)
Brewmaaaaan
just buy some APC white gauge faces https://honda-tech.com/forums/images/smilies/emwink.gif you'll be set https://honda-tech.com/forums/images/smilies/emthup.gif
Brewer 08-08-2004 06:15 PM
Re: (2.0L EK)
Haha, I was only talking about swapping the odometer assembly behind the guage face. JESUSDREAD brought up a good point:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JESUSDREAD &raquo;</TD></TR><TR><TD CLASS="quote">1st off there are no screws on the face of the jdm eg6 cluster</TD></TR></TABLE>
Looks like it's a no go.
.BigSexy 08-09-2004 09:11 AM
just remeber the conversion factor, alot easier to deal with IMHO, 1 mile=1.609 km
Brewer 08-09-2004 09:17 AM
Re: (egcoupe94)
The whole point is that I have a zero-mile US odometer waiting to go in with my new motor
TurboEH2 08-10-2004 08:02 AM
Re: (BrewerHatch)
here try what this guy did.
https://honda-tech.com/zerothread?id=845485
Member 00841 08-10-2004 08:08 AM
Re: (VTECschmetec)
cdn is not what we are discussing it still wont fit by the km cutout on jdm cluster so NO that THREAD does not WORK!
TurboEH2 08-10-2004 08:10 AM
Re: (JESUSDREAD)
ummm no need to get vicious kiddo. who pissed in you corn flakes? also i have seen this done to a EG6 (jdm sir) cluster in the ENDLESS track car. so do not tell me it cannot be done. https://honda-tech.com/forums/images/smilies/emwink.gif
Member 00841 08-10-2004 08:51 AM
Re: (VTECschmetec)
w- a cdn LOL were talking usdm no need to hate im just relating maby im wrong but my usdm and the other jdm are diffrent were not talking about cdn i know that one will work !
TurboEH2 08-10-2004 09:59 AM
Re: (JESUSDREAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JESUSDREAD &raquo;</TD></TR><TR><TD CLASS="quote">w- a cdn LOL were talking usdm no need to hate im just relating maby im wrong but my usdm and the other jdm are diffrent were not talking about cdn i know that one will work ! </TD></TR></TABLE>
huh what????? wtf is CDN do you mean CDM? i wasnt hating, i was stating what i know.
