HELP WIERD NOISE FROM eNGINE!!!!
ok let tell u guys hopefully u can help me. Well the other day i fill up gasr (91) from my normale 89 and then all the sudden i start hearing a wierd noise a rattling like a helicopter is in my enginebay. when i first turn on the car after it cools the sound is pretty loud then i hold the clutch down and the sound goes away. Or sometimes goes down to where i can barely hear it, then i let the clutch back in (neutral) and the sound comes back. After driving a while the sound seems to get barely noticebale. When i hold the clutch down and roll to a stop the sound keeps happinging until iam at a dead stop with the clutch held down. i really hope u guys can help thanks in advance.
p.s freaaking out !!!! feels like hawaii 5-0 under my hood !!!
it is a 94 dx with a sohc nonvtec !! thats why i posted it here
Re: HELP WIERD NOISE FROM eNGINE!!!! (gezer)
yo this is just an idea but my dad had an 87 integra and he had the exact same probelm i dont think it has anyhting to do with you changing gas i think ure fly wheel is warped my dad had to bring his in and get it resurfaced it was liek 400 dollars which suxs but i think thats what it is good luck
Re: HELP WIERD NOISE FROM eNGINE!!!! (hbvetteslayer)
400 bucks for a resurfaced flywheel!?
Where in God's name did you get it resurfaced.
When I did my clutch I took it to the shop and they did it for 25$ and I picked it up an hour later.
It might be a warped rotor or it can also be a bad pilot or throw out bearing. The pilot bearing is the bearing in the center of the flywheel disk and the throw out bearing is the one that slides back and forth on the spindle that pushes the clutch in and out. So my guess would be the throw out bearing.
Re: HELP WIERD NOISE FROM eNGINE!!!! (Paranoid Android)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paranoid Android »</TD></TR><TR><TD CLASS="quote">400 bucks for a resurfaced flywheel!?
When I did my clutch I took it to the shop and they did it for 25$ and I picked it up an hour later.</TD></TR></TABLE>
Most likey he didn't have the flywheel out of the tranny. He brought the whole car in and the shop had to remove the tranny (min like 200).
ITR9
07-05-2005 09:55 PM
