help..why does my battery keep dying..
okay, when i first bought the car it was okay. But after 2 months i go to start my car after work and it wouldn't turn on. I test the battery and it was no good. So i put in a knew battery and now its died again. WTF is worng with my car.
Could it be the alternator...
Its a 92 civic hatchback Dx.
Re: help..why does my battery keep dying.. (SpdFrk)
could be a (master) ground, under the main fuse box, under the hood near the battery.
I had a bad connection there, took one alternator install and a new battery for me to figure it all out. nice huh? it was all rusted under the main fuse box so I cleaned it all up and no more problems.
good luck
good luck
so i have to take the fuse box out to see if the master gorund is rusted??
Thanks for the help..
[Modified by SpdFrk, 12:44 AM 11/15/2002]
could be your alternator draining your juice.. go 2 a garage and have them test it.. They would probably check for free if you acted like you were going have them fix the problem.. then make some stupid excuse up about not having enough money this week and you will bing it back asap.. then do it yourself b/c they diagnosed your problem..
lmike6453
01-16-2009 06:55 PM
