HELP - What B-series axle is this? Drivers side is male -Instead of female?
Bought a ek hatch with a gsr swap.
Drivers side CV is gone, went to replace but the cv shaft is a male and the intermediate shaft is female???
What was this off of? I need a new one but don't know what car these came on? I have 2 00' SI driver side but the are female......UgH!!
TIA!
TIA!
Re: HELP - What B-series axle is this? Drivers side is male -Instead of female? (caspers_hatch)
The male side goes into the hub. The female goes into the intermediate shaft. What you have to do is get a hammer and hammer it out of the shaft, not easy i tell you right now.
Re: HELP - What B-series axle is this? Drivers side is male -Instead of female? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">The male side goes into the hub. The female goes into the intermediate shaft. What you have to do is get a hammer and hammer it out of the shaft, not easy i tell you right now. </TD></TR></TABLE>
When I replaced my clutch, I didn't take the intermediate shaft apart from the axle. I couldn't get it apart.
-Shane
-Shane
Ok. I thought i explained the problem well....anyway....i'll try again.
I know the male goes in the hub. The other end (which is female on every car i have owned) on this is actually a male and the Intermediate shaft is the female???
I thought i could just use a passenger side axle but they are about 5/8" longer?
Any one know what this setup came from so i know what axle to order?
Oh so your intermediate shaft has a female and male? Wow thats far out there. No clue which one that came from. Its B series though for sure? Because i have never seen that.
The int. shaft is a female. Both ends of the axle are male. i have a gsr b18c1...i am not an idiot...just baffled as ****.
I have been playing with these things for too long and i have never seen it this way.
JDM maybe? I am ******* clueless
Any one? I need an axle today..yesterday actually. This sux.
I actually have a JDM GSR and mine arent like that. My axle is male/female same with the intermediate shaft.
Pics would be alot better too.
I meant like the early jdm b16 from a CRX? I think that is what they are from.
I don't want to pull the axle just to take a picture, its pretty easy to imagine,
On 99% of b-series the drivers side cv axle has a male shaft on the hub side and a female on the Intermediate shaft side. Mine has MALE shafts on both ends.
i will see if i can get a pic without pulling it apart.
here is a pic but you can't see the shaft. I would have to pull the axle to get a good pic and i don't want to pull it until i have the replacement.
Any one with ideas or a NORMAL intermediate shaft for sale?
Sorry about size. This laptop isn't mine. Top is my motor...bottom is axle. You can tell its differant.
Re: HELP - What B-series axle is this? Drivers side is male -Instead of female? (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster »</TD></TR><TR><TD CLASS="quote">ummm the 93-older Integras used that</TD></TR></TABLE>
damn. never would have guessed. I know nothing about those beasts.
Any differances in the two? Should i switch it out for the 94-01? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caspers_hatch »</TD></TR><TR><TD CLASS="quote">damn. never would have guessed. I know nothing about those beasts.
Any differances in the two? Should i switch it out for the 94-01? Thanks</TD></TR></TABLE>
if it aint broke, dont fix it
yea its from a 90-93 teg. no big difference, just gotta remember that for your drivers side u order the 90-93 axles, because of the intermediate shaft. this happened to my friend shortly after he bought a hatch.
Re: HELP - What B-series axle is this? Drivers side is male -Instead of female? (BoOstedEM1)
i have had that strut bar and sticker since before you were old enough to drive.
Glad you like it.
Glad you like it.
AlexanderTheGreat
07-10-2007 12:11 AM
DTS
10-06-2006 08:11 AM
