Help w/ oil in spark plugs in B seires
i keep gettn oil in my spark plug on my 94 LS motor....im sure its the O rings gaskets on the value cover...im mostly having slight oils by cyclinder 4 (close to dizzy) if anyone else have had this problem and fixed it please leave opinons....another quest is that if i take out spark plugs wipe it clean and smog it ya think id pass..? JW nad also is p30 Si.....? thx for reading
Crazy Honda Guy
Re: Help w/ oil in spark plugs in B seires
i use some extra sealer on them when ever i install them. Did you buy oem? Some of those aftermarket gaskets fit like crap....oem Honda is the way to go
ya.. i did put silicons on them like a grip..actully ahaha....and i bought em from serblings west if uve heard of that.....ya think can it be one of the longs screw by the cam gears because its like slightly striped but u can still tighten it tho...any other suggstions guys.... i really appreicates yas opinons tho by the way
Spark plug tube gasket or seal and get some Gasket Maker Over the gasket or seal, it will work but u have to do a 100% A+ job not a half *** job
clean the valve cover and head thoroughly before you put it on.........
if you have a leak near dizzy its either cam seal or dizzy o ring
