help with vtec wiring on a D16z6 swap
I'm in the process of swapping a d16z6 in my 93 civic cx. i'm using the stock cx harness so i understand that i need to run thw vtec wires and the 4 wire 02 sensor.
i have the wiring diagrams and the ecu pinouts but i had a few questions about the names of thing.
on the picture below, what it this sensor called (above oil filter)?
on the picture below (vtec solenoid), what is the green plug called and what is the gray lug called
any input is greatly appreciated. thanks!
Re: help with vtec wiring on a D16z6 swap
^^^^^thanks. i got few other questions as well that i could not find from searching. the water pump, timing belt and tensioner from the d15b8 was changed about 5K miles ago. can i use these parts and the crank pulley from the d15b8 to the d16z6? thanks
slambedcivic
12-29-2002 08:14 PM
