HELP Vtec not working
Old 10-27-2004, 01:44 PM
civic32958's Avatar
Default HELP Vtec not working
I have a 95 EG hatch with a b16a2 swap. Had a turbo on it and it blow the bottom end. Ordered a new bottom end from a website, the guy said it was a b16a2 , everything fits and runs except rear motor mount is about 1 inch off.Double checked vtec wiring and manual powered up vtec sloneid and it works, also tryed another computer and it does not work. Now with everything on and running turbo too, everything works except the vtec. if someone could help maybe i got a b16a1 , and why doesnt the vtec work?? HELP
Old 10-27-2004, 02:39 PM
Falqon's Avatar
Default Re: HELP Vtec not working (civic32958)
car warmed up enough? You are moving right? Plenty of oil pressure?
Old 10-27-2004, 02:58 PM
ThatsMyEG's Avatar
check your vtec solenoid gasket
Old 10-27-2004, 02:59 PM
jayzonmyfeet's Avatar
Default Re: HELP Vtec not working (Falqon)
car is warmed up and i have plenty of oil pressure, dont you think it could be the bottom end
Old 10-27-2004, 03:00 PM
Unceasing Measure
Archidictus's Avatar
Default Re: HELP Vtec not working (jhmaccp3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhmaccp3 &raquo;</TD></TR><TR><TD CLASS="quote">car is warmed up and i have plenty of oil pressure, dont you think it could be the bottom end</TD></TR></TABLE>
Why would the bottom end have anything to do with the head? Are you throwing any codes? Are you hitting a rev limiter or anything of the sort? How long has this been a problem?
Old 10-27-2004, 03:06 PM
DumpedSi's Avatar
Default Re: HELP Vtec not working (Archidictus)
if you're unsure about what block its clearly stamped on the block if its b16 a1 2 or 3
does your speedometer work? If the speed sensor isnt working for whatever reason vtec wont crack
Old 10-27-2004, 03:08 PM
Braco11's Avatar
Default Re: HELP Vtec not working (Slammed Si)
check grounds as well
Old 10-27-2004, 07:58 PM
Falqon's Avatar
Default Re: HELP Vtec not working (Braco11)
no, even if you don't have a vtec bottom end, it has entirely nothing to do with it. If you couldn't use a B18a or b, then half of the guys in HT wouldn't be here.
Terrible One
09-06-2006 02:42 PM
95gsr_integra
04-10-2006 11:16 AM
TrueNorthStar
10-14-2004 08:14 PM
Nsane1
06-12-2004 04:47 PM
labatia
19
05-12-2004 10:57 AM
Quick Reply: HELP Vtec not working
