help with valve cover?
I sprayed my valve cover flat black and it looks like shat, so I was wondering if anyone knew how to get it back to my original finish...paint thinner didn't work. Thanks.
Re: help with valve cover? (CandyRedHatch)
what valve cover do you have,..is a dseries or bseries cover??? im guessing dseries,...if so then just use paint stripper,..you can get it at any auto store,...spray on and let sit for 5-15 miins,..it will start to bubble and then just wipe off,...WARNING,..do not let it get in contact with your skin,..it will itch and burn
well if you wanted to go back to the wrinkle black it had then i dont think its possible to strip the flat black off and save the wrinkle black finish it came with,..so in other words just strip it the way i told you to do it in my earlier post,..actually i like the bare metal look better anyways,...you can also try repainting it after you stripped it and sand it,..good luck
HT White Ops
Re: help with valve cover? (WiDeBoDyEK)
...just use paint stripper...you can get it at any auto store...
Re: help with valve cover? (BlackDeuceCoupe)
you wont be able to remove the black and keep the krinkle. But i use aircraft remover from auto zone or pep boys. Just spray it on and let it sit. works real good.
Re: help with valve cover? (2000SIsparky)
Try brake parts cleaner first. It should take the new paint off and leave the stock krinkle finish behind for you. Two spray cans should be sufficient.
