Help with Trans (tried searching)
I tried searching for info relevant to the trans found in a 93CX but I couldn't dig up anything. In short, what I'd like to know is:
1: What trans (code if possible) comes attached to this D-series.
2: Is it hydro or trans?
3: If it's cable, why should I bother going hydro.
4: Will Axles from an auto 91 LS mate to the CX's hubs.
Thanks.
Thanks.
Risky Business
Re: Help with Trans (Black FMIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black FMIC »</TD></TR><TR><TD CLASS="quote">I tried searching for info relevant to the trans found in a 93CX but I couldn't dig up anything. In short, what I'd like to know is:
Thanks.</TD></TR></TABLE>
1. S20... but you can tell a DX/CX/VX tranny from a EX/Si by numbers cast into the housing. Just above the filler plug is a set of numbers.
P20/A000 is for DX/CX/VX
P20/B000 is for EX/Si
Other than that, tranny must be split apart to know for sure which one you have.
2. Hydro
3. Its hydro, dont worry about it
4. No, you need to use 88-00 Civic d-series axles
2. Hydro
Re: Help with Trans (BauleyCivic)
1: P20? Thanks.
2: Okay.
3: Better still.
4: Guess I can use the stock ones then. Is any particular year/make any beefier than these pencils that are in there now?
2: Okay.
3: Better still.
ttt
i-VTEC_do_you
08-06-2006 03:49 PM
