HELP! TRANNY OIL SEAL!
Old 02-21-2005, 11:59 AM
WrongWD's Avatar
Default HELP! TRANNY OIL SEAL!
Howdy, i have an s21 b16 tranny, and I have an oil seal, but im not entirely sure where it goes, because i have the part number, but not the manual number. part number and description are as follows:
91216-ph8-005
OIL SEAL (28X41X7)
if someone could please tell me which part # this is, that would be greatly helpful, i was searching and i found this, could it possibly be part #16? The inner diamerer looks like it lines up with everything else in the diff, so perhaps i should take out the diff and see?
thanks in advance
Old 02-21-2005, 01:28 PM
WrongWD's Avatar
buUmp
Old 02-21-2005, 02:28 PM
doublejz's Avatar
Default Re: (WrongWD)
if it looks like this (which im betting it does)
or #16 then its an axle seal.
Old 02-21-2005, 02:58 PM
WrongWD's Avatar
thats the one! so do i pop off the tranny casing, and where near the diff does it go?
Modified by WrongWD at 12:11 AM 2/22/2005
Old 02-21-2005, 03:44 PM
Jmunk's Avatar
Just pull the axle out and pull the old one out and use the same size socket to drive the new one in. Done.
Old 02-21-2005, 04:10 PM
WrongWD's Avatar
Default Re: (Jmunk)
i cant seem to see where it would go....no disassembly of the tranny needed? all i see are metal pieces, i dont see a similar one
Old 02-21-2005, 04:20 PM
ABK
ABK's Avatar
Just pull out the axle and you will see it. You can pull it out (pry it out) and pop a new one in.
Old 02-21-2005, 04:36 PM
WrongWD's Avatar
Default Re: (ABK)
gentlemen, this is all i see
Old 02-21-2005, 04:57 PM
WrongWD's Avatar
ah okay i called honda, and they said that its the seal behind the input shaft. thanks all!
Old 02-21-2005, 05:23 PM
adictionbass's Avatar
WTF, what is pictured above is not an input shaft seal. Its an axle seal. You pop out the axle, there is one pushed in on either sides of the trans, pop it out, push the new one in. Use a big socket and a hammer or something of that nature.
Old 02-21-2005, 06:46 PM
ABK
ABK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD &raquo;</TD></TR><TR><TD CLASS="quote">ah okay i called honda, and they said that its the seal behind the input shaft. thanks all!</TD></TR></TABLE>
Yeah okay keep on thinking that. Is it me or it looks like there is already something pressed in there. I need an angle pix.
Old 02-21-2005, 06:48 PM
Default Re: (ABK)
i think thats just the outter bearing on the diff. All he might need to do is stick the axle seal in there...
Old 02-21-2005, 06:51 PM
ABK
ABK's Avatar
Default Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">i think thats just the outter bearing on the diff. All he might need to do is stick the axle seal in there...</TD></TR></TABLE>
that's what I said too, but I guess it's not working for him somehow.
Old 02-21-2005, 07:43 PM
WrongWD's Avatar
right, upon closer inspection i decided that it was not the same as the pictured one above, though it was very similar.
Old 02-22-2005, 01:57 PM
doublejz's Avatar
To me it looks like the remains of an axle seal is there. Looks as if all the rubber from the axle seal has been ripped off.
Looks like a little bit of rubber left over right here
Thats what I see anyway
Old 02-22-2005, 02:00 PM
doublejz's Avatar
Default Re: (doublejz)
you may want to ask a honda dealer what TMB208C2 is (i think i read that correctly off of your picture) that would answer all your questions.
89 ed6 FTW!
Transmission & Drivetrain
10-22-2010 07:09 AM
EK45VTi
11-26-2006 01:13 AM
EFresh
07-31-2006 01:44 PM
95civic_b20turbo
06-12-2005 06:31 PM
revv
02-22-2004 05:45 PM
Quick Reply: HELP! TRANNY OIL SEAL!
