Help taking off white faced gauges
Im going to take the gauges off....
I tried searching but i must suck at it but im lookin for like a white face gauge install DIY , so i can reverse the steps.
I already took the cluster out, and the plastic cover will pop off if the little mile reseter wasnt there. Ha i have to take the gauges out tonight and fix it by school tomorow. help
Re: Help taking off white faced gauges (EGcivicBoy)
if yours is the same as mine was... then i worked with that plastic cover in my way.
but i unscrewed those two tiny screws on the gauges..
then you gently slide it off through the needle.
since u dont want your white faces then you can bend them slightly to get them off.
just tamper with the needles too much.
hope that helps
hope that helps
Re: Help taking off white faced gauges (GTCX94)
how do i take that offf
just pull the **** off on the trip meter. then unscrew the tiny philip heads on each gauge and slide it through. be careful not to break the needles. if you dont want the gauge anymore, just cut them.
Re: Help taking off white faced gauges (O.G triple O.G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G »</TD></TR><TR><TD CLASS="quote">just pull the **** off on the trip meter. then unscrew the tiny philip heads on each gauge and slide it through. be careful not to break the needles. if you dont want the gauge anymore, just cut them.</TD></TR></TABLE>
yep thats it, just pull the little bastard till it comes off, then follow as he said, its quite simple
whats up with the BOLD fonts. are you trying to attract attention by using bold letter.
as for your question, sand the plastic with 1500 grit then spray a layer of clear after. if u dont know what i mean dont worry about it. just soap water.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G »</TD></TR><TR><TD CLASS="quote">whats up with the BOLD fonts. are you trying to attract attention by using bold letters? </TD></TR></TABLE>
Ya i was trying to get it done fast which i did. Thanks for all your help HT
