HELP WITH SET UP!!!
Old 07-14-2007, 08:00 PM
tru3civicsi's Avatar
Default HELP WITH SET UP!!!
I GOT A 00 B16...
CAN B18 CRANK SHAFT AND RODS FIT?? AND TYPE R PISTON??
AND IF IT DOES FIT CAN I USE THE JRSC HI-BOOST MADE FOR A 00 SI SAFELY???
- I heard that an stock 00 si did 230WHP, i was hoping to i can pull more horses if i had b18 internals!!! ----IS THIS POSSIBLE----
Old 07-14-2007, 08:08 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: HELP WITH SET UP!!! (tru3civicsi)
b18 what?
c, c1, c3, c4, c5, c6, c7?
b18b1, a1?
Old 07-14-2007, 08:24 PM
gsr crank
Old 07-14-2007, 08:25 PM
Ek Forever y0!
I know the blocks are not identical. I'm not sure on the compatibility but I would guess no.
Sounds fishy putting a 1.8L crank into a 1.6L motor.
Old 07-14-2007, 08:44 PM
Default Re: HELP WITH SET UP!!! (ek forever guy)
i know!!! thats what my friend told me.. he said it may not fit properly/wont work... but the mechanic i know said it would...so am traing to find out....the whats right...
or you think i should just leave the crank alone and put type r piston and camshafts!!! but if i do this would it be safe on a supercharger boosting 10psi (JRSC HIGH-BOOST) rated at 230 on a stock b16 with basic bolt ons
Old 07-14-2007, 08:46 PM
94c1v1cex's Avatar
nothing is good with a supercharger... just my .02 turbo ftw!
edit: unless it has more than 4 cylinders
Old 07-14-2007, 08:47 PM
Ek Forever y0!
If your just worried about the integrity of the crank, get it balanced and leave it alone.
There are 400-600whp hondas using stock cranks. They're bulletproof.
Old 07-14-2007, 08:48 PM
Default Re: HELP WITH SET UP!!! (94c1v1cex)
Old 07-14-2007, 08:55 PM
ok..right on so you think i should just change my pistons!!! i just dont want to go turbo because.. i heard you need to baby the danm thing and its hard to tone and i dont know beside i drive my car every day!!! and on the other hand the JRSP high boost put 230whp on a stock b16.. more reliable than turbo.. but i know turbo is quicker..
QUESTION if am doing the JRSC can the BUDDY CLUB III camshafts work or its better to use turbo cams?
Old 07-14-2007, 08:57 PM
Ek Forever y0!
I think you should inspect the whole engine for wear and just replace parts. Or buy a new longblock.
Old 07-14-2007, 09:01 PM
i got like 80k on my motor!! but i was planning to rebuild it thats why the guy at the shop told me if i wanted him to put gsr crank... so you think is better to just rebuild the motor.... but should i use the JRSC HIGH BOOST..i heard its good... my options are all motor or supercharge..
Old 07-14-2007, 09:06 PM
Ek Forever y0!
IMO, there's a huge philosophy on why small displacement and superchargers don't mix.
99.9% of small displacement forced induction tuners do with turbo's for a reason.
SC's make for rough daily driving too. Always in boost.
Old 07-14-2007, 09:14 PM
what would be the best set up for me knowing that i have a b16? wha would you do??? realibility wise
Old 07-14-2007, 10:08 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tru3civicsi &raquo;</TD></TR><TR><TD CLASS="quote">i know!!! thats what my friend told me.. he said it may not fit properly/wont work... but the mechanic i know said it would...so am traing to find out....the whats right...
or you think i should just leave the crank alone and put type r piston and camshafts!!! but if i do this would it be safe on a supercharger boosting 10psi (JRSC HIGH-BOOST) rated at 230 on a stock b16 with basic bolt ons</TD></TR></TABLE>
My ex-girlfriend can change her own oil...that doesn't make her a mechanic. Likewise getting an automotive-related associates degree from the local community college doesn't make one a Honda guru.
The B16 has a different deck height vs ANY b18, so you need shorter rods. Its cheaper to get a B18 block if you're shooting for 230whp with a supercharger. Honestly though, I don't think you're read to take that step (turbo/sc). Hell, I don't think you should be taking any engine apart just yet.
BTW all the forced induction info in this entire subforum is bunk. SC's aren't always in boost, turbos aren't unreliable (sc's can throw belts like a redneck father), and you don't want *cast aluminum* high-compression pistons in a FI motor.
Old 07-14-2007, 11:55 PM
Horseofcourse's Avatar
Default Re: HELP WITH SET UP!!! (HiProfile)
Get a cheap LS or CRV block and throw that damn b16 head on it and call her good! dont forget to read how to build a reliable one of thoose and just build the **** out of the bottom end and get the head worked on like a savage
boostedgsr1234
03-20-2008 09:36 AM
MenaceL.A.671
06-29-2004 05:50 PM
AmakakeruRyuNoHirameki
09-28-2002 04:50 PM
Quick Reply: HELP WITH SET UP!!!
