HELP!! RC 550CC INJECTORS RESISTOR BOX?
Old 01-16-2010, 06:02 PM
em1effekt's Avatar
Default HELP!! RC 550CC INJECTORS RESISTOR BOX?
OK h/t
i just picked up some rc 550cc injectors
i havent yet but i am going to throw them on a b20v with a b16 head...
i been trying to do some research now that i found out they are low impedance injectors....but i get lost with the info....
will i need a resistor box??
i have an obd1 p28 s100 hondata ecu with and obd2 converdion to obd1 ecu harness
going in a 99 civic si
need some help
Old 01-16-2010, 06:27 PM
cleansi's Avatar
Default Re: HELP!! RC 550CC INJECTORS RESISTOR BOX?
no they dnt require a resistor box
all these years models running 550cc do not require resistor box
1992-2001 Acura Integra (1996+ REQUIRED )
1996-2001 Honda Accord 4 Cylinder Engines (REQUIRED Clips 1992-2000 Honda Civic (1996+ REQUIRED Clips
1996-2001 Honda Prelude (REQUIRED Clips)
1988-1991 Honda/Acura - Must remove OEM resistor box and use OBD1 style injector connecting plugs
Old 01-16-2010, 06:32 PM
em1effekt's Avatar
so mine is a 99 civic si that means i would need the clips??
do you have a pic of what they look like...
Old 01-16-2010, 08:11 PM
apexi_rsx's Avatar
are these injectors high impeadiance injectors or saturated? if high impeadiance then you will need a resistor box. you will need to splice in OBD1 injector clips or RC injector clips to swap these injectors.
Old 01-16-2010, 10:52 PM
mrharmonic's Avatar
the sell injecter clips b dog
Old 01-17-2010, 12:28 AM
em1effekt's Avatar
theyy say low impedance 550cc rc injectors....
Old 01-17-2010, 09:51 PM
em1effekt's Avatar
bump...still lost...
Old 01-17-2010, 10:41 PM
thumper64's Avatar
you need a resistor box.
http://www.hondata.com/techlowohminjectors.html
You can get one from older Accords, 92 and older Integras, 91 and older Civics I believe. I think there's some "Twinkie" style resistor boxes also. Or I got one that's extra from an Accord. PM me and I could figure out shipping.
Old 01-18-2010, 07:22 PM
em1effekt's Avatar
BUMp
em1effekt's Avatar
bump for some help
Old 04-26-2010, 06:51 PM
buckner2009's Avatar
ya got the same ones there low need a risistor box; and the clip located under intake many on 96-00 ' eg on driver side firewall' black and yellow' they will run the car if its tuned but wont start good and wont idle good till ur inm boost then run rich' wrong omhs
Old 05-03-2010, 01:07 AM
em1effekt's Avatar
changed em for some high impadance 550's =]
jdmdikk
04-01-2009 06:13 AM
immorality
05-24-2008 03:46 PM
213374U
07-19-2005 11:55 AM
allablur
12-09-2003 03:07 PM
Quick Reply: HELP!! RC 550CC INJECTORS RESISTOR BOX?
