Help with radio and dome light not working
Old 01-16-2009, 05:21 PM
static-x's Avatar
Icon2 Help with radio and dome light not working
Need some help on my bro's 92 civic 4door. He came down a week ago and said his radio and dome light havent been working for awhile. So i did the usual and checked the fuses under the dash and none were blown. The sticker diagram for the fuse box in the engine bay is missing so i dont know if any fuses in there relate to dome or radio probs. Any ideas on what i could check? Ive got a multi tester, but never really used one. thx in advance guys
Old 01-16-2009, 05:38 PM
standbackimapro's Avatar
Default Re: Help with radio and dome not working
It usually has 2 fuse boxes the one on the driver side panel, and the one under the hood
your best bet would to be just look at all the fuses in the box under the hood and replace any that are bad
If they are good your gonna have to run a wire from an ignition source ( somthing that will turn on with the car) to the radio
Old 01-16-2009, 07:45 PM
static-x's Avatar
ya i did that. all fuses are good. even his dome light bulb is good i checked it out in my car.
Old 01-16-2009, 09:45 PM
trustdestruction's Avatar
Default Re: Help with radio and dome light not working
does the dome light work at all? manually? or just doesn't work when you open the door?
Old 01-16-2009, 09:58 PM
1LowSol's Avatar
Old 01-16-2009, 09:59 PM
Master Detailer
98civdx's Avatar
take that multi tester and use it to see if the outlet is even get power for the dome.
and then same thing for radio.
you may have a bad wire or wires.
Old 01-16-2009, 10:02 PM
Originally Posted by 1LowSol
i don't see why you're confused...
the dome light can either be manually turned on, or set to off but on with the doors open. I am asking if the dome light works at all, under any circumstances.
Old 01-16-2009, 11:17 PM
static-x's Avatar
Dome light dont come on neither way, by door or on position. He was telling me the radio and dome both went out the same day so im thinkin some wires are messed up somewhere. I'll mess with the mulimeter tomorrow
Canucksfan101
10-27-2014 07:56 AM
jonobird
07-11-2011 01:06 AM
EJ1civic coupe
12-15-2008 03:03 AM
lilo_goki
09-26-2008 10:33 AM
gechalx
Audio / Security / Video
03-28-2002 09:05 AM
Quick Reply: Help with radio and dome light not working
