Help with Power windows/lock conversion on EK
Alright guys, i need your help on this one.
I bought 2 complete doors off of a honda civic Si/EX (not sure) but they are powered locks/windows
I bought a complete 98 EX coupe harness
I have a 97 Hatchback
I have installed the doors, layed down the harness. everything plugs up under the fuse box, doors everything.
cars fires up just fine also.
here is the problem, both windows roll up and down fine. BUT the locks is acting weird.
I can hit the LOCK button on the switch and the driver side with lock, when i hit unlock, the driver side does not react. Passenger side would not react to neither.
NOTE: As you guys know we need a relay in the fuse box under the dash, I couldnt find one, so i went under the hood and yanked out the relay for the a/c condensor. (no a/c at the moment so dont matter) I plugged it in and it works the relay is 4 prong.
Please help
Please help
Re: Help with Power windows/lock conversion on EK (peterislazyek9)
That relay is great, and it works just like factory. However, you have just use a wire splice, plug and find the negative and positive....
I'll post the diagram once I get home tonight, that should help all of you guys.
Re: Help with Power windows/lock conversion on EK (Pensar71)
I thought it was plug and play no splicing or anything because i have the doors and the floor harness
JOSEP.TM101
08-15-2013 09:20 AM
crazyLemons4.20
12
05-29-2013 06:43 PM
Civic_4life
01-02-2012 04:34 PM
