help plz
help plz
i have a stock 93 civic cx and when ever i try to redline it, it stops at only 4500 rpms. Why cant i get any higher cuz i looked up the specs and it said it shoudl rev about 6k rpm.
Re: help plz (nerd28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerd28 »</TD></TR><TR><TD CLASS="quote">i have a stock 93 civic cx and when ever i try to redline it, it stops at only 4500 rpms. Why cant i get any higher cuz i looked up the specs and it said it shoudl rev about 6k rpm.</TD></TR></TABLE>
there are a couple of factors:
1. you have a cx motor.
2. there's no need to revv that high, especially on a cx motor
3. you have a cx motor.
4. when's the last time you did a tune up?
5. you have a cx motor.
oh, by the way if i forgot to tell you YOU HAVE A CX MOTOR!
Re: (nerd28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerd28 »</TD></TR><TR><TD CLASS="quote">srry i was just wondering
if the motor is cutting off at 4.5K, then most likely it's the rev-limiter cutting it off. has nothing to do with the motor.
Re: help plz (philosofy1)
More info is needed for us to help you, such as:
Is the check engine light on?
If so, what codes is it throwing? (search to find out how to do this)
Has this condition been developing, or did it happen all of a sudden?
Typically, when an engine stops revving at around 4500 rpms and sounds like it's hitting the rev limiter, it means that the ECU is keeping the engine in "limp" mode. This means the rev limiter is lower and it runs more conservatively because the computer thinks something is effed up.
Hatch It
11-22-2004 08:09 PM
C4wrx
12-30-2001 03:31 PM
