Help Please,honda civic 95 DX "1", replace engine
Old 06-29-2011, 11:34 PM
Cardona95DX's Avatar
Icon2 Help Please,honda civic 95 DX "1", replace engine
I want to install this engine
http://www.japangeneralmotor.com/ind...ec-engine.html
because the engine I want to install is from Japan but someone told me that if I put this engine I have to add more parts to fit my 95 honda civic DX coupe "1" MT.
I want to know if it's true or not, is important to know if it's true or not because I want to order next week the engine.
Old 06-30-2011, 12:28 AM
apexi_rsx's Avatar
Default Re: Help Please,honda civic 95 DX "1", replace engine
NO you wont have to add anything , just use parts that are on the motor u have right now.some things on JDM motors we don't have here on our usdm motors like egr valves etc... just use your usdm intake manifold and ecu and u wont have any problems swapping it in. they are still pretty much plug and play. that is if your swapping a d16 or another d16 ,but if u have a d16 and your swapping a b series you will be better off finding a usdm intake manifold with all the sensors to use. then using the jdm intake manifold with a egr valve.
Old 06-30-2011, 12:30 AM
NotAJDMFanBoy's Avatar
It would be like any B series swap. You'd need a clutch, trans, axles, T mount, probably a driver's side mount, and the ECU. And you'd need to wire in VTEC. JDM motors lack knock and the VTEC oil pressure switch. Both are easy enough to work around.
And you would have to reuse your engine harness, extending a couple wires as necessary.
Old 06-30-2011, 12:31 AM
Originally Posted by apexi_rsx
yes, its true some things on JDM motors we don't have here on our usdm motors like egr valves etc... just use your usdm intake manifold and ecu and u wont have any problems swapping it in. they are still pretty much plug and play.
he has a civic dx, that's a del sol vtec engine. He's going from D to B, so intakes no swappo.
And the Civic VX is the only Civic with an EGR. I know of no 1990-00 integra with a EGR.
Old 06-30-2011, 12:42 AM
ok so i need clutch, trans and axles for the new engine????
Old 06-30-2011, 02:05 AM
apexi_rsx's Avatar
yes and integra spindles
Old 06-30-2011, 04:30 AM
Seagull Management
94EG8's Avatar
Not needed, Integra axles work just fine in civic knuckles/spindles.
Old 06-30-2011, 08:27 AM
Icon2 Re: Help Please,honda civic 95 DX "1", replace engine
OK SO I DONT NEED ANYTHINF FOR THE NEW ENGINE RIGHT AND WHAT ABOUT THE TRANSMISSION IT WILL FIT FOR THE NEW ENGINE????????????
Old 06-30-2011, 06:57 PM
Seagull Management
94EG8's Avatar
You'll need a B-series hydro tranny to go with the new engine, along with a clutch and shift linkage from a '94 - '01 Integra or '99 - '00 Civic Si.
npfernando
06-10-2009 03:22 PM
axtran
04-30-2006 10:48 PM
Riddance
12-17-2003 07:34 PM
theta1602
07-18-2002 03:17 PM
S13Koop
07-23-2001 09:14 PM
Quick Reply: Help Please,honda civic 95 DX "1", replace engine
