Help Please (which alternator)
Sup guys, I gotta 2000 ex coupe with an jdm b16 swap. I'm using the factory wiring
harness, anyways my alternator took a shit and need to know which one to get. I got one before but when I went to install in the bottom bolt went through but the top wouldn't (it was a reman from advance auto). Anyways which one will drop right in there no cutting splicing, etc. basically plug-n-play. Also, this time iI wanna get an OEM one. I also heard that the jdm b16 motor and the U.S. ones have different alternator brackets. Is this true if so which alternator do I need. Sorry about the long rant. But please help it was already done wrong once. I wanna which one will work and fit for sure. |
Re: Help Please (Stillmatic22)
cant really help you but i will give you abump so maybe the person who can tell you will see you post good luck https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Help Please (Southtownracing)
come on, please
b16 sir I sir II or what ? usdm b16a2? Did you switch over all your stuff to obd2? you gotta give some better info if you want an answer
Re: Help Please (mjrage)
I haven't swtiched anything, I used the stock wiring harness with an OBD2 to OBD 1 conversion harness. I didn't cut anything. the motors from an delsol vtec so I'm assuming 92-95 o whatever.
