help please?
help please?
well, I once again need your help. I replaced my brake master cylinder and everything went ok. I bled the breaks..but when I test drove it, the brakes had kind of a hard feeling. It was tough to press down upon it, and the brake did not respond as well. Its hard to stop...because I have to really step on the brakes to stop. Do I need to bleed the brakes some more? Is it air still present that is causing this? any info will greatly help me. thanks all once again.
Former Moderator
Re: help please? (WongFeihung)
You might have double ringed your m/c when you installed it.
There is a rubber ring that is on the end of the m/c shaft where it goes into the booster. The new m/c comes with a new ring, but sometimes the old ring sticks. That *might* be your problem.
What you're describing sounds like a bad booster, or perhaps too big of a m/c for what brakes you have.
What booster, m/c, and brakes are you running and on what car?
Re: help please? (B18C5-EH2)
its on a 93 Civic Si. honestly, IM not familiar with all the names of what brakes, or what booster I have. I just knew that the mc was leaking and whenever I pressed the brakes, the brake pedal would slowly go in..I then , went to auto zone..got me a new mc for my si..then simply installed it then bled the brakes with my friend. any help would be appreciate it. thanks guys.
jasonweaver88
06-29-2007 10:31 AM
