Help please 4 door civic 92/95 rear seat
I need help, I have to remove the rear seat from my 92-95 civic 4 door.
Its a european VTI and the rear seat is 2 bucket style seats with a centre console.
I have tried and can't figure it out.
I have searched but nothing on this car.
Anyone help?
Anyone help?
Re: Help please 4 door civic 92/95 rear seat (slamdunkcivic)
On a hatch you unlock the back of the seat like your going to fold it down and on the outside hinge point there is a little clip. Take the clip off and slide the seat over and it should come out. Do the same for the other side. The bottom has one 10mm on the front side, remove that and lift the back of the seat and pull up (you have to work it a little to get the metal clip out of the slot, not hard you just have to find the angle and it pops out).
That's how you do it in a hatch and 2 door GS-R...hope that helps.
Good luck
Good luck
first, the center console thing in the middle has a tab a the bottom that you can just pull off, there are two screws there that you have to remove. them open the console where the cup holder is, clean everything out and there are two more screws way back in the pocket of the console. remove those. then just pop of the yop of the console softly and remove the two screws there, (i cant remember if there are any screws but im pretty sure they are) after those screws are out just pull up and out the center console. next remove the headrest. there are gonna be two more screws on the outer edges of each seat that are though to reach. near where the door is, pull on the back part of the seat and you should see the first one. then do the same for the butt part of the seat and youll see the other. repeat for the other side and you are done. The FINAL most important step is once everything is out of the car, put it in a box and ship it out to ME. Good luck
sageuvagony
12-25-2008 12:54 PM
nicko360
02-09-2007 04:13 PM
