Help with pinging please help
Hey i totalled my 94 sho and picked up a 97 civic dx from a local girl. Since i got it it which was like 2 weeks ago it makes a pinging noise under accelleration. I do not know hondas yet which is why i am asking im in a whole different world now than with my old car. Its wierd i tried a few things just to see the result...when sitting there in neutral and revving the car does not make the noise to my knowledge, it is only when i am accellerating and if i am cruising it seems to stop like if i am not on the gas. It is like a guick repetetive tinking noise that it makes and i would really really like to get rid of it. any and all suggestions, comments and advice are greatly appreciated. help me out with getting rid of this noise please...thanks in advance,,,
~eric~
~eric~
Re: Help with pinging please help (importtuner1413)
pinging is caused by the timing being to far advanced, so if u have changed timing or if u started using a higher octane fuel this may be the cause for the ping, try to put a timing light on it if possible or if u do use high octane gas try using 87 once, hope this will help, good luck,
it is a stock d16y7 in there...how do i check the timing lol i never done it before although i do have a timing light...i dont think the timing was ever changed it was owned by a girl as a daily college driver before me.
bump.....problem is still there...it does not seem to do it when i am revving in neutral only when i am in gear and on the gas. I am trying to figure out timing i want to do that but i dont know how to...i will try again in the am though. so basically only things it could be are timing and valve lash? anything else it could possible be????
thanks
eric
thanks
eric
Re: Help with pinging please help (Crx_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx_Civic »</TD></TR><TR><TD CLASS="quote">pinging is caused by the timing being to far advanced, so if u have changed timing or if u started using a higher octane fuel this may be the cause for the ping, try to put a timing light on it if possible or if u do use high octane gas try using 87 once, hope this will help, good luck, </TD></TR></TABLE>
So lower quality gas will get rid of an engine pinging? And all this time I've been paying out the *** to fill up on premium in order to abuse my engine.
Re: (importtuner1413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importtuner1413 »</TD></TR><TR><TD CLASS="quote">i run 87 and tried a tank of 93 and the like tinging/clacking noise was still there.</TD></TR></TABLE>
93 isn't magic juice... it's not going to cover up any issues you have. It's simply a deterrent to detonation.
As stated further up in the thread, it sounds like your timing is too far advanced. Hook your timing light up to power/ground and the inductive lead to plug wire #1 which is all the way to the driver's side of the engine. Point the light down at the groove near the engine mount and you should see the hash on the crank pulley when the light is flashing. It should line up with the groove that you're aiming at if your timing is set correctly.
If not, your timing belt may have skipped a tooth or your distributor may be incorrectly adjusted. If it looks new, maybe someone tried to replace the distributor and didn't adjust the timing. If the timing belt was replaced recently, maybe it was incorrectly installed.
Re: (PhantomLord)
Both Hondas I've owned would ping under high load / low RPM with the timing set correctly. The transmission in the DX makes it a real bear, just downshift when climbing hills, etc.
My wife's bone stock '00 Echo even pings when you load it like that.
dillonsi
07-26-2008 09:51 AM
el arbi
15
05-18-2003 09:06 AM
