help with oil pressure switch and some unknown wire
i have a 96 b18c and i was wondering how to put the oil pressure switch in? there's no thread from what i can see. am i even able to put it on?
here's another pic
also, where does this black hose go to? does it go to where the yellow arrow is pointing?
Modified by egg_baLLa at 3:51 AM 2/7/2005
here's another pic
Re: help with oil pressure switch and some unknown wire (PhatAcuraIntegra)
yeah dude that was a mistake.
i was in a hurry to make the thread.
anyone know though?
anyone know though?
Re: help with oil pressure switch and some unknown wire (egg_baLLa)
there should be a lil nipple on the throttlle body that the line goes to. as for the oil pressure if there is no thread on it i would recomend to get it helicoiled or just swap the thing out with a diff one. i have like 6 of them if u need one.
Mr. Badwrench
Re: help with oil pressure switch and some unknown wire (fabs)
JDM obd2 engines have no hole for the spool vlave oil switch. instead of oil pressure, they use the vss signal to know when and when not to engage vtec. you can get the housing from the dealer but it is about 200-250 bucks. i have been told you can just ground it but i havent tried that.
Re: help with oil pressure switch and some unknown wire (boostedcivicsir)
yeah i know how to do the grounding, but its not that simple for me.
i have to take it to state ref again pretty soon so im probably just going to have to buy the housing. does anyone know the part number for the housing?
Mr. Badwrench
from san leornado i am about 95% sure it is this number. judging by the price it is,
http://www.slhondaparts.com/br...EC%29
15810-P30-005
15810-P30-005
2 options, but the vtec solenoid itself from someone and then plug in.
I'd just do this though... at the ecu, connect the 2 vtec wires with a wire. This is how my p28 is wired and it works perfectly. No vtec pressure switch code, and vtec is happy.
Re: help with oil pressure switch and some unknown wire (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">2 options, but the vtec solenoid itself from someone and then plug in.
I'd just do this though... at the ecu, connect the 2 vtec wires with a wire. This is how my p28 is wired and it works perfectly. No vtec pressure switch code, and vtec is happy.</TD></TR></TABLE>
yeah i know how to do that -- A4 to D6 --
but as stated above, i cannot simply do that.
i've also bought the oil pressure switch the other day at the dealership for about $80.
but now i know to just buy the housing so i think im just gonna do that instead.
as for the vacuum hose, does it go to where the yellow arrow is pointing?
fabs stated earlier that there was a little nipple on the tb so im just double checking.
thanks for the help so far guys.
