Help Need Honda Guru
Hi there to all Honda guru.Need some help here. I own a honda Civic Eg9. Currently run B18cr (r=remix). I was wondering is it possible that a combination of B18CR HEAD(Never Skim) + B18CR block (Never Skim)+ B16B piston PCT + B16B Rod (length 142.42mm) + B20B Crank or B18CR Crank. Why B20B crank? Cos 89mm while b18cr 87.5mm. I know type r crank got full weight balance. But B20B Crank can increase your CC may up to 19++ cc if use B20b crank. (correct me if I'm wrong) Pls don't advice me to use B20B Block. Thank You.
pm4nudes
Re: Help Need Honda Guru
I don't know if I fully understand this but did you mean to say you want to run pct pistons and rods in your b18? You are aware that with the longer rods and large dome on the pct pistons your going to have clearance issues right?
X2......LoL
I honestly did not understand much of what he wrote,
but I think this will help him... http://www.zealautowerks.com/bseries.html
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please read the Stickies.
d16dcoe45
13
10-08-2006 02:36 PM
