Help need answer now 2.5 or 3 bar sencor ?
Hi guys one of my buddys has a motorola 2.5 bar sencor and is saling it to me cheap so my power goals are 300-350whp and latter going for 450whp
Its a d16zc forged turbo etc...turbo its a garrett t3/t4 57 trim . Now will il be ok with the motorola 2.5 bar or will it bi better a 3 bar
Its for daly drive to ...
Re: Help need answer now 2.5 or 3 bar sencor ?
2.5 bar will read up to ~22psi. 3 bar will read up to ~28psi. I haven't run the numbers, but I'm pretty sure you can make 300-350 on that turbo before you'll need the 3 bar.
Assuming you're chipping it to tune, it doesn't matter what ECU you use.
If you aren't chipping it to tune, I'll start taking bets now on how long until your motor grenades.
True, but running a P28 won't hurt anything. Just ignore the VTEC settings and set the crossover to an RPM the motor will never see.
Well thanks for the offer but my buddy that has the motorola 2.5 bar he has a p06 ecu chip for sale to thats why i was asking ? I need one anyways so wich ones the best for my motor and its going to be tuned on a dyno if that can help
If the P06 is cheaper, then that's probably your best choice. What do you plan to tune it with? Crome, Neptune?
It mostly matters what you and your tuner prefer. If the person tuning it is more experienced with one, go with that one. You'll get a higher quality tune since they will know the ins and outs of the software better.
He should be proficient with most, but some tuners do more work with one specific program, so they will know all the "quirks" and that sort of thing just due to being more experienced with it. And that translates into a smoother tune.
My buddy is saling obd2 to obd 1 harness with p06 chip ecu and motorola 2.5 bar sencor for 175$ is that a good deal
street_ride14
03-12-2010 06:25 PM
