((HELP)) my vtec aint working...
i noticed that behind the block theres a sensor with no wire.. how can i hook that up?? is that the reason it aint working?? oil seems right.. the computer is right.. the other 2 sensors are right excpet that one..b16a2
Re: ((HELP)) my vtec aint working... (crazyguy)
yes sir i do and thats cuz of that sesor and cuz i dont have a cat, i have a stight from the mainfold apexi dunk..olskool
HT Order of Merit
Re: ((HELP)) my vtec aint working... (SumOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SumOne »</TD></TR><TR><TD CLASS="quote">yes sir i do and thats cuz of that sesor and cuz i dont have a cat, i have a stight from the mainfold apexi dunk..olskool</TD></TR></TABLE>
Knock sensor not working will not cause VTEC to not work. There has to be some other issue.
VTEC relies on three things:
RPM
Coolant Temp
Oil Pressure
As long as your wires are correct and you have those three things, it should be ok.
RPM
Coolant Temp
Oil Pressure
right now im heading to the hospital to pic up sum1 .. ill be back but leave me inputs ill be back in a few!!
Re: ((HELP)) my vtec aint working... (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">
RPM
Coolant Temp
Oil Pressure
As long as your wires are correct and you have those three things, it should be ok. </TD></TR></TABLE>
wtf.... if he has a cel the engine will go into failsafe and not let vtec engage and if he has a knock sensor not working then he would hav a cel
cel=no vtec
RPM
Coolant Temp
Oil Pressure
cel=no vtec
RPM
Coolant Temp
Oil Pressure
untrue...even a cel for your vss can disable vtec
RPM
Coolant Temp
Oil Pressure
RPM
Coolant Temp
Oil Pressure
WTF? there is only one way you could have came up with conclusion.
1. you don't have a vtec motor.
2. you never had and/or worked on a vtec motor.
either way you don't know what the hell you are talking about. please stay away from giving mis leading info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SumOne »</TD></TR><TR><TD CLASS="quote">i noticed that behind the block theres a sensor with no wire.. how can i hook that up?? is that the reason it aint working?? oil seems right.. the computer is right.. the other 2 sensors are right excpet that one..b16a2</TD></TR></TABLE>
first put back the bulb like i told you, then connect your knock sensor and you'll have your vtec!
RPM
Coolant Temp
Oil Pressure
chinoslines
07-05-2010 03:59 PM
