help me on taking out this bottom piece of the engine.
how would u take out the pulley that spins AC, PS, alternator belts wen tha timing belt is dc already?? help fast...........
Re: help me on taking out this bottom piece of the engine. (dwnthehatch)
ok... u know tha bottom piece pulley that spins the belt which spins the ac, ps, and alternator... the crank... im tryin to get that off so i can get the bottom cover to come off where i can put my timing belt on... i dont know wat its call...
Re: help me on taking out this bottom piece of the engine. (wizzards581)
u talking about the crank pulley? thas gonna be a bit*h to take off. i tried to take it off about a month ago, but then realized that u could get to the tensioner with the cover on. ha. but umm, u need a way to stop the crank from rotating while you're trying to loosen it. it's torqued to 132 ft lbs. i think. there is a tool you can buy for like 32 bucks to stop the crank pulley from moving, i saw the site on here, but if you're strapped for time, you could always stick a big screwdriver in your flywheel. i've tried a pulley wrench but its not strong enough for the crank pulley. or u could use an impact wrench to loosen the bolt, you don't even need to stop the crank from moving. i wish i had one of those when i did it. well good luck.
Re: help me on taking out this bottom piece of the engine. (tominos)
yes i know its a pain... and the crank spins... wat else can i do??? im still stuck... i heard u can start the car to make it come out?? but my crank has no timing to the cams... its gona be bad... help anyone?
fraid not, but you CAN do it without taking the crank pully off, just loosen the tensioner all the way and it can be slipped on and off, I have done it twice.
John
John
nope, never took a pic while I was doing the job. sorry. if you are at such a point where you don't know what to do next or don't have the right tools, man you may have to go and take your car to a professional rather than risking mucking your ride up man, just my .02!
Moderator
Re: help me on taking out this bottom piece of the engine. (ImprtTuner88)
it is called
CRANK PULLEY
to take it off....
you need as someone said an impact gun with mad torque.....
or get the crank pulley wrench....it cost bout 75 bucks.....and you will need some 4 foot breaker bars....
CRANK PULLEY
to take it off....
Re: help me on taking out this bottom piece of the engine. (Chad)
o yea?? so i cant do it with any of my hand wrenchs?? last time i was told to start the car using the hand wrenches... but that was wen i had the timing belt still on.. its gona be bad cuz this time theres no timing belt... so jux go buy?
