help me please with my b18b swapinto a 95 civic
help!! me please with my b18b swap into a 95 civic
i b18b it has disrobuter from 91 on it, is there a wire diagram or wire harness i could use to keep from having to buy a new one because it is brand new (it is a non v-tec motor) also what about shift linkage on civc will it work? does anyone have a driver side axle for 95 integra.
Modified by kurtlmcculloch at 9:45 AM 8/23/2007
Re: help me please with my b18b swapinto a 95 civic (kurtlmcculloch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurtlmcculloch »</TD></TR><TR><TD CLASS="quote">does anyone know if my type r trany is better then just regular b18 hydro?</TD></TR></TABLE>
A type-r tranny will have shorter gears than your ls tranny. Therefore, which one you use will depend on how you drive. If you like to drive fast and accellerating quickly is a priority, than you want to install the typie tranny. If fuel economy is more your thing, than you want to keep the ls tranny.
Even though you lack the knowledge of the RED search button i'll help you out.
https://honda-tech.com/zerothread?id=983454
Because im lazy too il tell you this: delsol a/c bracket, ls computer, If you turbo your motor use the ls tranny(longer gears), if you go N/A go type R(shorter gears), Ls shift linkage. Do your own research on the dizzy problem.
Atreyu3388
06-09-2007 04:52 AM
