help me install a hood, noob here
how do i remove and install a hood for a 99 civic? i looks in the FAQs above and i didn't see anything and i searched before. if there is a DIY here then it would be nice. if not can someone tell me how to do it? pics would be nice. thanks.
Re: help me install a hood, noob here (hkboy87)
1. Pop the hood from inside the cabin
2. Unlatch the hood
3. Prop the hood up
4. Get a friend to hold the other side
5. Take a 3/8 drive 10mm socket (I believe its 10) and loosen up the bolts (2 per side) attached to the bracket
6. Toss the wrench to your friend and have him do the same
7. Take off the hood and lay it on the ground (use somthing to rest it on)
Installing goes pretty much the same way, line it up and install the bolts. Done!
2. Unlatch the hood
3. Prop the hood up
Re: help me install a hood, noob here (95ProjectEJ1)
Nailed it. Do that and you will be fine. There is nothing more to it unless you want to add more people to the job. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">1. Pop the hood from inside the cabin
2. Unlatch the hood
3. Prop the hood up
2. Unlatch the hood
3. Prop the hood up
Re: help me install a hood, noob here (Cpt.GargameL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cpt.GargameL »</TD></TR><TR><TD CLASS="quote">Nailed it. Do that and you will be fine. There is nothing more to it unless you want to add more people to the job. lol
Haha yeah, you could switch it up and have two people hold it while one loosens
HT White Ops
Re: (hkboy87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hkboy87 »</TD></TR><TR><TD CLASS="quote">that sounds easy to do. so after i loosen the bracket from the car, do i remove the bracket from the old hood and mount it on the new hood?</TD></TR></TABLE>
Don't take the brackets off the car. Take the brackets off the hood. Then just bolt the new hood to the brackets ON the car.
Re: (hkboy87)
If you don't have new brackets (yes) if you do and you want them on (no)
EDIT: Yes it is extremely easy to do. (I wish everything else was like that lol
Guest
Posts: n/a
Re: (hkboy87)
what I would do if i were you is get 2 buddys to help you, pop hood and prop it up, lay blankets on each fenders just to be safe, as well as put 2 layers of masking tape alll the way around the hoods edges. Then remove the 4 10mm screws, and the hood will be free, assuming you disconnected the windsheild washer lines
yea i just took a look at some pictures on this forum and the latch looks easy to take off. also one more question, my hood is not aligned right, how do i adjust it?
monicle
40
04-26-2012 05:36 PM
fryman
01-09-2009 03:21 PM
integraautox
08-12-2002 10:43 PM
