HELP: making a trunk floor board
Old 02-22-2006, 10:11 PM
cilvia's Avatar
Default HELP: making a trunk floor board
anyone done this?? mines is bent and cracked and somethin more than 5 pounds will fall right through it...thought of trying to make my own...anyone know of a good, cheap, light, strong, easy to cut, materal to use for my trunk board...its on a 97 ex coupe if you need to know..thanks
Old 02-22-2006, 10:31 PM
ZipTieGUy's Avatar
go to home deport, theres this wood/cardboard material. its like 5 bucks for a big *** peice and you can ask the dude at the machine to cut it. then you take it home and trim it to the size of the stock board.
it has holes in it. like holes every inch. its about a quarter inch thick, solid, cheap
edit: you can also cut it into 2 peices, zip tie it, so you if you have no spare tire you can open it up and put stuff underneath, even if you have a sub on top, get what I'm saying?
Old 02-22-2006, 10:36 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">go to home deport, theres this wood/cardboard material. its like 5 bucks for a big *** peice and you can ask the dude at the machine to cut it. then you take it home and trim it to the size of the stock board.
edit: you can also cut it into 2 peices, zip tie it, so you if you have no spare tire you can open it up and put stuff underneath, even if you have a sub on top, get what I'm saying?</TD></TR></TABLE>
Brilliant idea. I made my own out of 3/4" MDF. =P
Old 02-23-2006, 01:47 AM
badpootie's Avatar
Default Re: HELP: making a trunk floor board (cilvia)
I not only need the board but also the cloth cover. Did you just make your board? what did you use?
Old 02-23-2006, 02:02 AM
mrbigg9032's Avatar
Try using thin plywood becuase it sounds like u have a leak in your trunk and if u use that cardboard again its just going to go to ****.
Old 02-23-2006, 04:17 AM
allanonjj's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Brilliant idea. I made my own out of 3/4" MDF. =P</TD></TR></TABLE>
sO DID i. i COVERED MINE IN THAT CHEAP CARPET YOU CAN BUY FROM wAL-mART FOR LIKE $8 A ROLL(i HaTe CApS) It looks reealy good though.
burtonzt
Honda Civic (2001 - 2005)
12-14-2007 01:15 AM
Antilag
09-24-2007 10:14 AM
Lil_Wyte
18
12-28-2006 08:41 PM
insomniac791
06-05-2005 11:45 AM
Deemeetree
05-30-2005 09:31 PM
Quick Reply: HELP: making a trunk floor board
