HELP! Lights dim when at idle
Just installed a new alternator and double checked all connections. As well as getting the battery tested too.
When I push the clutch in and let the rpms fall, they will fall and the car will either dim the lights or the car will stall out... Not sure what the problem is! Thanks In Advance |
Re: HELP! Lights dim when at idle (ej8pwr)
any imput is appreciated
Check your grounds and all your wires.
Re: HELP! Lights dim when at idle (Blu99teg)
all my wires to what?
i had a problem almost like this accept mines did it when i hit the brake pedal on a stop u might wanna check ur ground wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8pwr »</TD></TR><TR><TD CLASS="quote">all my wires to what?</TD></TR></TABLE>
All of your wires to and from the battery, to your lights, and to your alternator again. |
