Help!! Lighting problem Turn my parking lights or headlights and rear left blinker doesnt blink and
Help!! Lighting problem Turn my parking lights or headlights and rear left blinker doesnt blink and stays on...but when i turn the lights off the blinker works fine
i have replaced botb bulbs front left and rear left and front left socket from honda
should i replace the rear socket but why should i if it works fine wihtout the parking/headlights on please help.............thank you so much
Re: Help!! Lighting problem Turn my parking lights or headlights and rear left blinker doesnt blink
just make sure you have the right bulbs.....they can do some crazy things if they are wrong
i had the same problem with my right front, the front right parking light went on but the front right blinker wouldnt go on. so i checked the wiring and redone the splicing the idiot before did and it was the same, nothing. i then changed the bulbs and the same thing, i thought the same as you, why change the socket, then i just did it, it turned out to be the socket. 6 months of thinking of trying to figure out what it was, down the drain.
so yeah, it might be the socket, just take the socket off a working side, then plug it into the non working side, then put the bulb on and test it, simple.
good luck lmk
good luck lmk
Re: (doubleoazn03)
I put A NEW SOCKET from honda and bulb in the front left and the bulb is light 30 times more bighter then the right but with all lights off the front and back left side wokr but the min i turn on te parking light or the headlights the left back light stays on and the blinker doesnt work at all im gonna try changing the rear socket thanks for some info
pliskin8
07-07-2011 06:30 PM
2001B18C1GS-R
Lighting
04-24-2008 10:41 AM
