Help: knock & ping
Old 01-16-2004, 08:01 AM
dizzyroc88's Avatar
Default Help: knock & ping
while accelerating the car will studder alot and then ill hear a knock...i changed the fuel filter and it all went away for a couple days but now its back again...what could it be?
thanks in advance
Old 01-16-2004, 08:50 AM
TeamNextGenChris's Avatar
Default Re: Help: knock & ping (dizzyroc88)
how long since you last did a complete tune-up?check your timing too.
chris
Old 01-16-2004, 08:59 AM
dizzyroc88's Avatar
Default Re: Help: knock & ping (TeamNextGenChris)
i checked the timing yesterday it was fine...its abuot an month and a half since the last complete tune up
Old 01-16-2004, 09:01 AM
SOHC_MShue's Avatar
what gass are you running? What is your ignition timing set at?
Old 01-16-2004, 09:02 AM
dizzyroc88's Avatar
when i took out the fuel filter there was alot of rust in it... i thought two things my gas tank is rusted on the inside and the other...it was the original fuel filter. i bhought it off some old guy that used it about 3 weeks a year...i was hoping it was just that the filter had not been changed but i dont know im stumped
Old 01-16-2004, 09:04 AM
dizzyroc88's Avatar
medium grade....the iginition timing...the same way it came out of the factory it hasnt been messed with
Old 01-16-2004, 09:11 AM
how long have you owned the car?has it done this since you bought it,or did it just recently develop?what car and engine?when you say you checked the timing,did you actually use a timing gun,or did you mean that the distributor hasn't been moved from the factory position?
chris
Old 01-16-2004, 09:23 AM
dizzyroc88's Avatar
i used a timing gun and all the lines matched up...92 civic hatch d15z1 ive had it for about 1 year the problem just recently developed. i just changed the distributor when the i did the tune up
Old 01-16-2004, 10:38 AM
dizzyroc88's Avatar
Old 01-16-2004, 12:30 PM
dizzyroc88's Avatar
Old 01-16-2004, 12:36 PM
hmmm....i'm thinking here.how many miles on the motor?you might want to try some kind of top end cleaner like Seafoam.i always use it when i swap in a motor-really gets all the carbon out of the intake and head.if you've got a lot of buildup that can definately lead to knocking.it only costs a few bucks and is easy to do.really makes a difference.
chris
Old 01-16-2004, 12:39 PM
dizzyroc88's Avatar
its has 76xxx miles
Old 01-16-2004, 12:44 PM
the engine cleaner is worth a shot.i've had higher mileage motors before that would ping even with proper timing and octane.got all the built up carbon out with the Seafoam and it cured the ping,and made them run smoother.
chris
Old 01-16-2004, 12:48 PM
dizzyroc88's Avatar
and what i just spray it on the motor like if it were a degreaser?
Old 01-16-2004, 12:51 PM
it has directions on the can-you can get it at most auto parts stores....basically,you warm the car up(with the intake arm off),and spray the Seafoam into the throttle body.you let it sit for a few minutes,then start the car back up and let it run until it burns it all away.
you might also want to pick up a new set of NGKs while you're there,as sometimes the Seafoam can foul the plugs out.after you get done,you can throw in the new ones.
chris
Old 01-16-2004, 01:00 PM
dizzyroc88's Avatar
thanks for the help..ill go try that out..
ngk? spark plugs?
Old 01-16-2004, 01:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 &raquo;</TD></TR><TR><TD CLASS="quote">ngk? spark plugs?</TD></TR></TABLE>
yeah,i'd get a set of standard NGK plugs while you're there-should be under $2 a piece.
chris
luggss
10-13-2009 07:11 PM
ruffrhyder
09-12-2008 01:55 PM
dragaholic
03-16-2007 07:02 AM
dragaholic
02-23-2007 11:05 PM
civic_slut
11
07-28-2004 07:08 PM
Quick Reply: Help: knock & ping
