HELP: JDM D15B VTEC Motor Tapping Noise
Old 05-31-2010, 06:57 PM
streethondar's Avatar
Default HELP: JDM D15B VTEC Motor Tapping Noise
I have a 1995 honda civic with a JDM D15B VTEC. The motor is making a tapping noise. (not a knocking). I have adjusted the valves to the correct settings. If you lean over the valve cover and smell you can smell gas rich.
What could this be?
Old 05-31-2010, 07:06 PM
jerryegk24's Avatar
Default Re: HELP: JDM D15B VTEC Motor Tapping Noise
If you adjust your valves already, i guess it would be your clicking fuel injectors.
Old 05-31-2010, 07:40 PM
ok, i will swap them out in the am. thanks. i will let you know what happens
Old 05-31-2010, 07:50 PM
xero_xero's Avatar
what are the build specs?
additions to the car?
origination of the motor? mileadge?
any other problems?
Old 05-31-2010, 08:07 PM
i know none of the answers to the question you just asked me. I will try to swap the injectors in the am and see what that does.
Old 05-31-2010, 08:23 PM
xero_xero's Avatar
95 civic. coupe, hatch, 4 door?
automatic or manual?
which ecu are you running?
did you do the swap?
where did the motor come from?
Old 05-31-2010, 08:31 PM
95 civic coupe
automatic
stock non-vtec ecu
i hired a tech to do the swap but watched helped with the swap.
i bought the motor form a friend.
when i bought the motor i told the guy to keep the intake manifold... WHICH has the GOOD INJECTORS!!! LIKE A IDIOT I AM! so i will swap my injectors with a know good set i have here. and wa la should fix my issue.
Old 05-31-2010, 09:15 PM
xero_xero's Avatar
red civic you bought off craigslist?
hole in the d15b7?
painted black rims?
motor was out of a crx which still had the manual flywheel?
Old 05-31-2010, 09:16 PM
clayton?? haha!
Old 05-31-2010, 09:27 PM
xero_xero's Avatar
if someone adjusted the valves for you, then the injectors will only tick, any more is an issue...
the extra fuel is more than likeley the nonvtec ecu on a vtec engine. the injectors were dirty as hell when i pulled them out temporarily. told you they looked icky.
still no cel? there should be a tdc/cmp code thrown. the injectors jsut dont fire at the right time.
Old 05-31-2010, 09:30 PM
still no cel. i will try to change them and see what happens. Me and my dad did the valve job with the a feeler gauge.
Old 05-31-2010, 09:32 PM
xero_xero's Avatar
they needed to be andjusted to .006. we shall see.
Old 05-31-2010, 09:34 PM
we did 9 on exhaust and 7 on intake
Old 06-01-2010, 07:02 AM
FIXED! CYL 4 injectors was failing! replacing all the fuel injectors fixed my issue.
Robert Krouse
Honda Civic (2001 - 2005)
04-18-2019 07:12 AM
4891jb
06-12-2015 03:04 PM
[Ennis_D]
06-05-2005 08:41 AM
slowstang101
15
03-28-2004 08:35 AM
bananacruzier
03-28-2002 10:33 AM
Quick Reply: HELP: JDM D15B VTEC Motor Tapping Noise
