Help installing Skunk2 Sport Shocks on Skunk2 Adjustable Coilovers...
PROJECT COMPLETED see last post]
Shocks on with coilovers, problem after lowing car off jacks.. Doesn't look right (see my last post way below)
Last Question [SOLVED]:
On the 3rd pic. again, there's a small part of metal that points in a triangle downward.. (parallel with those two welded on mount/nuts) when I re-installed the pieces correctly and slide the bottom shock on the damper fork, it stopped (obviously) where the triangle piece points downwards was.
SO, even though there is a damper pinch fork bolt in place, why is that piece there, wouldn't it hurt more than anything (since it might smash down into the damper fork)?
#2 Question Solved
Does anybody know what the two weird angled areas (welded on nut/mount) to bolt a screw/bolt are for (see PICTURE 3, bottom right)?
#1 Problem Solved
So I received my skunk2 sport shocks last week, and finally had time to get to installing them this weekend. I took off the skunk2 adjustables from the oem/stock shock and was going to put on the new skunk2 sports.. However, there are 2 rubber pieces and one fat washer for each shock, and I have no clue where they belong... Check out the pix below and maybe you can help??
This is the orginal setup (the thread piece that the coilovers go on aren't shown)
pic of my stock setup on stock shocks
Those are the pieces I'm talking about
That fat washer piece doesn't fit below where the bump-stop piece goes.. So no room to put those pieces, right?
Def. the wrong way, but not sure how to install it..
skunk2 shocks with the coilovers without those pieces or the fat washer
Up close pic of those red pieces
Modified by ke98248 at 5:10 AM 6/3/2007
Modified by ke98248 at 5:12 AM 6/3/2007
Modified by ke98248 at 9:54 PM 6/3/2007
#2 Question Solved
#1 Problem Solved
um, the red things replace the black things that look EXACTLY like them that are on your top hats i think they're called.
just use a screw driver and nudge em out.
HT White Ops
Yes, they're a urethane replacement for your tophat bushings. Knock them out with a screwdriver and a mallet, and remove the metal collar in between. Put it back together with the red bushings.
Re: (Eran)
See first post again (new question), original problem solved, but thanks for the answer again; as well as clarification for the washer question
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Yes, they're a urethane replacement for your tophat bushings. Knock them out with a screwdriver and a mallet, and remove the metal collar in between. Put it back together with the red bushings.</TD></TR></TABLE>
he can still use the little metal tube that slides onbetween the red bushings, wtf?
HT White Ops
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">
he can still use the little metal tube that slides onbetween the red bushings, wtf?</TD></TR></TABLE>
Yes.... why wouldn't he be? It's just a metal collar. You slide the old hard rubber bushings off and put the urethane on.
Re: (Eran)
See above post again. Sorry, last question.
Plus that metal collar doesn't receive much, if any wear; so using it again is def. the right choice. Plus they don't give you a new one of those anyways.
HT White Ops
On your shock fork, there should be a split or indentation where the bolt brings the two edges of the collar together. That little point on the shock collar goes into that split.
If you don't set it up like that, your shock will sit too high.
HT White Ops
Oh, by the way, you see those 4 beveled washers you have? The ones that seem to have sort of a dome on them?
Those go on the shock piston with the dome facing up, to give the bumpstop something to rest on. They will only go down to where the shock piston gets larger, so don't try and force it.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Oh, by the way, you see those 4 beveled washers you have? The ones that seem to have sort of a dome on them?
Those go on the shock piston with the dome facing up, to give the bumpstop something to rest on. They will only go down to where the shock piston gets larger, so don't try and force it.</TD></TR></TABLE>
yes, and they also give the top hat something to tighten down against.
Re: (Eran)
Thanks, I actually stayed up real late and finished it all, and did that too ^^ with the washers.. However, I lowered my car off the jacks and it looks like this on all 4 shocks!:
Anybody know what I did wrong? I did everything just how I thought it was supposed to go. I know that they are supposed to be about as tall as the two adjacent nuts that tie the shock to the chassis/shock tower. Here's a pic:
Re: Help installing Skunk2 Sport Shocks on Skunk2 Adjustable Coilovers... (ke98248)
HT White Ops
Did you forget the rubber bumpstops?
Also, you rebuilt the tophat the wrong way. The domed side is supposed to face up on the top side, and down on the bottom, so when together, it looks almost spherical (thus, why it's called a spherical bushing). They should never separate with that collar in.
Re: (Eran)
I put in the rubber bump-stops.. I can see how the top-hat is constructed incorrectly, but when I change that, it would still be poking thru, right? I wasn't sure what to do with the 4 metal washers (the fat ones) that I got, so I replaced the old piece that goes after the two poly. urethane bushing with that.. Was I supposed to put one of those washers after the bump-stop or ? That's what I'm starting to think I need to do.
Also, one of the collars for the rear is MIA.. When I popped off the bushings from the top hat, I didn't see one. Searched everywhere, so I'm fairly sure it wasn't there to begin with.. Do I need one of those really bad, or can it wait a few days while I drive the car around (go to school & work, then get the part and install, )
Got the triangle piece lined up..
close up of the current setup
last pic: \
last pic: \
HT White Ops
When putting together a shock it goes:
Nut
Cup Washer (cup lip facing up)
Urethane Bushing (dome up)
Collar
Top Hat
Urethane Bushing (dome down)
Beveled Washer
Bump Stop
Nut
Collar
Top Hat
Beveled Washer
Bump Stop
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">When putting together a shock it goes:
Nut
Collar
Top Hat
Beveled Washer
Bump Stop
Thanks, that helps a lot.. You should get a raise on H-T, lol.
Nut
Collar
Top Hat
Beveled Washer
Bump Stop
