help identifying a rear trailing arm
Location: So Cal where old pople try to race you, U.S.A
i have a rear trailing arm that i purchased from an importer locally and i've tried about 4 different wheel bearings and none of them fit.
99-00 si
94-00 integra
92-95 civic
94-00 integra abs
any ideas?
my passanger side hub/spindle looks like this
but the driver side towards the end of the where you would put the wheel bearing on it pops out a bit more it looks as if a race is stuck but it isnt.
here are some pics of the driver side hub:
that is the bearing pushed as far back on the hub as possible and you can see there is a big gap still.
the bearing on there now is for a late model integra abs, but the eg wheel bearing, 99 si wheel bearing, and non abs integra all fit the same.
99-00 si
94-00 integra
92-95 civic
94-00 integra abs
any ideas?
Re: help identifying a rear trailing arm
Use a 90-91 crx si rear wheel bearing. you can also use 92-00 dx or lx drum rear wheel bearings they are the same......if you need help let me know i have two of em pm if you want em..
Use a 90-91 crx si rear wheel bearing. you can also use 92-00 dx or lx drum rear wheel bearings they are the same......if you need help let me know.. i have two of em pm if you want em..
i know what im talking about..
FSRslug
04-21-2009 03:04 PM
sti99civicsi
12-08-2004 06:09 AM
