Help! Girlfriends civic is throwing a CEL.
Few weeks ago my girlfriends dad was trying to clean her engine bay shortly after that her check engine light came on. I tried to reset it by disconnecting the battery but it did not work. So I was wondering if there was anyway I can jump the ecu without taking it to the dealer.
Where are the jumper wires and how do I jump the code?
BTW its a 99 civic EX.
Thanks
Thanks
Re: Help! Girlfriends civic is throwing a CEL. (3gLudeH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gLudeH22A »</TD></TR><TR><TD CLASS="quote">Few weeks ago my girlfriends dad was trying to clean her engine bay shortly after that her check engine light came on. I tried to reset it by disconnecting the battery but it did not work. So I was wondering if there was anyway I can jump the ecu without taking it to the dealer.
Thanks</TD></TR></TABLE>
Passenger side kick panel.
Little blue 2 wire connector....put a paper clip in there and then turn the ignition to ON....the check engine light will start to flash a code.
Long = 10's
Short = 1's
Long = 10's
Short = 1's
Re: Help! Girlfriends civic is throwing a CEL. (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">Passenger side kick panel.
Long = 10's
Short = 1's</TD></TR></TABLE>
spade is right as usual
i had to do this on a 96 teg this weekend the 1 bit of advice i can give is. if there are no problems and the light just needs to be turned off having the jumper in will leave the light on and not throw any codes. so to shut it off you have to pop the hood and pull the back-up fuse for 15 sec.
HTH
Long = 10's
HTH
Re: Help! Girlfriends civic is throwing a CEL. (shepworldwide)
Thanks for the help!!!!! I know nothing about OBD2 or civics...you all can probably tell..lol....thanks again
Jimmy
10-07-2003 11:34 AM
