help with fuel line's
before sombody tell's me to search i already did...im having a problem with i think its a filter on my fuel line's it broke on once i put the clamp on it can sombody help identify this peice thank you
once i took the clamp and the line off i noticed it was broken
Try going to http://www.hondapartsdeals.com They have illustrated parts breakdowns and maybe you can find the part there. I tried looking for you but I couldn't find it. I was assuming this was on a b16.
Re: (v!taminb16)
Its just some device (I think its called a purge joint) to put together 2 vacuum lines going to the charcoal canister. Get a long piece of vacuum line and run it directly from the purge solenoid to the canister. You don't need that thing.
Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">Its just some device (I think its called a purge joint) to put together 2 vacuum lines going to the charcoal canister. Get a long piece of vacuum line and run it directly from the purge solenoid to the canister. You don't need that thing.</TD></TR></TABLE>
so i dont need it then are you aure
Re: (pgpbubble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble »</TD></TR><TR><TD CLASS="quote">You don't need that if your not worried about your vehicle being emission compliant.</TD></TR></TABLE>
will it harm my vehicle in any way
Re: (v!taminb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v!taminb16 »</TD></TR><TR><TD CLASS="quote">
will it harm my vehicle in any way </TD></TR></TABLE>
negative, only thing you need is a functioning pcv system
the emissions **** is just that... sheiit lol
Re: (MonkeyMagic)
holy crap, You just don't need the purge joint (the thing you broke). It will not, in any way, effect the way the EVAP control system works, that single piece is not needed, the rest is!!
Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">holy crap, You just don't need the purge joint (the thing you broke). It will not, in any way, effect the way the EVAP control system works, that single piece is not needed, the rest is!!</TD></TR></TABLE>
holy crap i was just making sure...thank's for the help
