help, fog light people ..this IS NOT a how to install question..
alright, first off this isnt an OEM fog light kit for the 92-95 civics...but anyway, the stupid connector got stuck in the switch and when forcing it out i managed to pull out all the wires...now i dont remember what wire goes where for the switch...can anyone help, or take a look at their switch and tell me where to connect these back in the plug? THANKS
the wires ( think the two yellow ones went on the outside, but im not sure)
the connector (4 wires and 5 places to put them )
and the back of the switch
Re: help, fog light people ..this IS NOT a how to install question.. (ShagPower)
did your fog light kit comes with some instructions, or can you read a name off of the fog light kit and look at the manufactues site for the wiring Diagram...
Did you put the lights on yourself?
Was the Factory Honda Wiring used for the Aftermarket fog lights?
Do you have the manual for the Fog Lights, Is there a Name on the Fog light that you can read? Is the Wiring diagram on the Manufactures Web Site.
Re: help, fog light people ..this IS NOT a how to install question.. (heavyhittersclub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heavyhittersclub »</TD></TR><TR><TD CLASS="quote">did your fog light kit comes with some instructions, or can you read a name off of the fog light kit and look at the manufactues site for the wiring Diagram...
no instructions, no name on the lights, they are not installed...its aftermarket wiring too (came with the kit)
nope, it doesn't give me any idea as to how to what pin out is the right one
if someone has a picture of their switch and connection thats all i need
lets label the pins left to right.. in 1-5
test the pins out for continuity with a mulitmeter, and the switch in both positions on and off... that will tell you which is the switched pins
another set of pins is the illumination and ground, using a 9v battery or 12v source test for that...
Re: help, fog light people ..this IS NOT a how to install question.. (TooManyTickets)
The two yellows are positive power going into the switch, one for the on light and the other to supply the signal to turn on the relay. The red is the signal wire going from the switch to the relay to turn it on and the black is ground.... From the way they wires are sitting in the first pic it looks like they'd be yellow red empty black yellow... but you'd have to either test the switches pins or open up the casing and see which wires are going where.....
Re: help, fog light people ..this IS NOT a how to install question.. (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TooManyTickets »</TD></TR><TR><TD CLASS="quote">my 0.02 Most often the black wire will be ground </TD></TR></TABLE>
no foolin?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX »</TD></TR><TR><TD CLASS="quote">The two yellows are positive power going into the switch, one for the on light and the other to supply the signal to turn on the relay. The red is the signal wire going from the switch to the relay to turn it on and the black is ground.... From the way they wires are sitting in the first pic it looks like they'd be yellow red empty black yellow... but you'd have to either test the switches pins or open up the casing and see which wires are going where.....</TD></TR></TABLE>
dont go by how they're set up, all i can remember is the two yellow wires go on the outside. ill take the casing apart and look
but it would REALLY BE HELPFUL if someone could take a quick picture of their connector just to show what order they are in...and it doesnt have to be the same colours
no foolin?
opening the switch up didnt really help anything
hi buddy, you long wait and search is over
i've have the same unit as you do!!!
if you were to place the harness facing up on your table ( as your picture!!!)
from left to right there are 5 pins
first pin: yellow/blue wire
second pin: red/green wire
third pin (the center): no wires
fourth pin: black wire
fifth pin: yellow/blue wire
i can't add picture in this form
just email me at therujan@hotmail.com and i'll send u the picture!!
good luck man
good luck man
Re: help, fog light people ..this IS NOT a how to install question.. (therujan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therujan »</TD></TR><TR><TD CLASS="quote">hi buddy, you long wait and search is over
good luck man </TD></TR></TABLE>
THANKS!!! couldn't have answered my question better
gianinline
10-29-2014 09:27 PM
