help engine loose oil !
hello evreyone..
i looked today under my car saw oil comes down from the oil pan area.
later checked engine oil and there was no engine oil..
the car is civic eg 93 esi d16z6 motor..
need help what cause the problem..
thanks
roy
Modified by roy civicHBturbo at 3:16 PM 10/27/2005
thanks
roy
Will you make something up for me please?
Re: (roy civicHBturbo)
Where exactly is the oil coming from when you say it's coming from the oil pan? You have to locate the leak first before we can tell you how to repair it.
Other than that, are you sure that's where you're losing the oil from? Are you leaking anywhere else? Are you consuming/burning oil? How are your gaskets and when was the last time you did the 30K mile service (valve cover gasket, plug grommets, etc)?
Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote"> when was the last time you did the 30K mile service (valve cover gasket, plug grommets, etc)?</TD></TR></TABLE>
i did all of theme in month ago. include timing belt and etc..
i can say when i push the gas pedal and clutch oild comes down quick from
the oil pan area. not all the time it happend.
what im sure know is that my motor loosing oil...
thanks for help
roy
thanks for help
roy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roy civicHBturbo »</TD></TR><TR><TD CLASS="quote">
thanks for help
roy
Ahh, you're from Isreal.
You should try to have someone step on the gas and see if you can see exactly where it's coming from. It could be somewhere from the block, or it could be as simple as an oil pan gasket.
NOTE: You want your signature to say "EG 93 SOHC turbo", not SOCH.
thanks for help
roy
Mr. Fuch-yu
Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">Ahh, you're from Isreal. </TD></TR></TABLE>
Yeah I had to check location too. If he was from America, I would have to flame the grammar or throw him a ritalin. Because in America, it either means you are too damn excited or your stupid. But for the progress with the English. I am genuinely impressed
-Red
-Red
infinkc
07-27-2009 12:02 PM
