HELP ENGINE LIGHT JUST CAME ON POSSIBILITIES...?
Old 08-01-2004, 07:35 AM
madlion's Avatar
Default HELP ENGINE LIGHT JUST CAME ON POSSIBILITIES...?
Well lately my car has been turning over a few times before it starts like the battery is dieing.. i just purchased this car its a civic si 00. it has about 47k on it and i think it could be the battery. ijust put a big system in it 5000 miles ago. the system is an xtant x1001 and a alpine deck. so the amp is pretty big [email protected] ohm. does the check engine light come on when your batteries about to go?
note:
modes done
greddy exhaust
weapon r intake
chipped ecu
sound system
kyb agx struts
i just had the struts switched out two days ago by abacus racing
madlion is offline
Old 08-01-2004, 08:05 AM
mjrage's Avatar
Default Re: HELP ENGINE LIGHT JUST CAME ON POSSIBILITIES...? (madlion)
I think the battery/charging light would come on if the battery were dying. Just go to Autozone and have them test it, its free. Have them test your alt with your system on/off and see if its putting out the req'd amps. Have them check your CEL's too.. they also do that for free, well some of them do.
mjrage is offline
Old 08-01-2004, 08:27 AM
RTFM
its possible you wont know **** til you check to see what code shows when you check the light.
v4lu3s is offline
Old 08-01-2004, 08:37 AM
EM1 MIKE's Avatar
Find the blue connector down by the ECU. Splice the brown and black wires together or use a paper clip and read what code it's flashing.
EM1 MIKE is offline
Old 08-01-2004, 10:03 AM
BoOs7eDSoHc's Avatar
Default Re: (v4lu3s)
BoOs7eDSoHc is offline
Old 08-01-2004, 10:08 AM
hatchling37's Avatar
Default Re: (BoOs7eDSoHc)
No, it's the combo of Weapon R and GReddy. Didn't you read in the papers about how the two have irreconcilable differences and won't be seeing each other anymore? They refuse to work together and now your battery is on strike, too. Bummer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">I think the battery/charging light would come on if the battery were dying. Just go to Autozone and have them test it, its free. Have them test your alt with your system on/off and see if its putting out the req'd amps. Have them check your CEL's too.. they also do that for free, well some of them do.</TD></TR></TABLE>
^What he said
hatchling37 is offline
Old 08-01-2004, 10:19 AM
madlion's Avatar
I JUST RAN A CEL AND THE OXYGEN Sensor is the problem it was only one code.. anyways i reset the ecu and the light didnt come back on from my way home from autozone.. maybe someone knocked something loose when i had the struts installed...
madlion is offline
Old 08-01-2004, 10:24 AM
madlion's Avatar
Default Re: HELP ENGINE LIGHT JUST CAME ON POSSIBILITIES...? THIS IS THE CODE THAT POPPED UP
P0133 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) Circuit Slow Response
so thats the code that popped
madlion is offline
Old 08-01-2004, 11:35 AM
mjrage's Avatar
Yeah normally I'd disconnect the oxygen sensor during a strut install. Its like number 1 in the helm's manual I think.
In retrospect, at least it didnt come back on yet.
mjrage is offline
Old 08-01-2004, 11:40 AM
Kamin's Avatar
Default Re: HELP ENGINE LIGHT JUST CAME ON POSSIBILITIES...? (mjrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">Yeah normally I'd disconnect the oxygen sensor during a strut install. Its like number 1 in the helm's manual I think.
In retrospect, at least it didnt come back on yet. </TD></TR></TABLE>
its because he hasnt gone through an entire drive cycle yet.
if it IS a real problem with one of the O2's it will come back on. the ECU does not look at every sensor, all the time. it only looks at them when its told to.
Kamin is offline
itrdave
07-19-2017 04:59 AM
EJ8_Man
04-13-2016 04:33 PM
GoodUsername
06-01-2015 01:47 PM
DJ Gurgla GSR
12-19-2005 04:27 PM
teal_dx
08-14-2003 12:58 PM
Quick Reply: HELP ENGINE LIGHT JUST CAME ON POSSIBILITIES...?
  • Ask a Question
Question Title:
Description:
