HELP!!! Eg wont start.
Im currently working on my neighbors 4dr eg, its getting NO spark or fuel. Replaced the main relay, still no power to the pump and no spark, cracks over all day though. Also cheked all fuses and they are all in good shape. Any input could help.
Re: HELP!!! Eg wont start.
Triple check 15A hood fuse 31 and 15A dash fuse 24.
Also make sure the G101 ground wire connected to the thermostat housing is clean and tight.
Next, unplug the MAP sensor, turn the key to ON(II), and measure voltage to body ground for each of three terminals in the wire harness plug. What voltages do you read for each wire?
all the fuses are good, the #8 pin on the relay (ground for the fuel pump) wasnt good, if i ground it seperatly the pump will prime and work on ignition but still no spark, im gonna check the map now
Checked the Ther.Stat Ground (G101) its tight and in good shape. Im going to check and see if the ecu is getting power tomorrow. Ill update if i stumble upon anything new.
sanegb16
17
07-19-2009 10:59 PM
Civic_07
04-05-2008 06:25 PM
3M TA3
09-02-2006 09:22 PM
