HELP EG FRONT LIP INSTALL!!!
gota stock SI front lip - plan to install on my 92 eg hb .. an as i noticed i dont have any bolt holes or screw holes under my bumber whre the lip would mount on .. i guess i gota drill some holes an just get nutz / washers an go at it ? anyone else have any advice ? thank you
Re: HELP EG FRONT LIP INSTALL!!! (nichols_si)
just make sure u dont mess up on the drilling..... im not sure but i think some ppl just screw it in with force.... do u know what i mean? but dont quote me on that.
not really cuz the lip needs to be securly on there cuz it comes a lil loose near the middle - i was thinking probably just get a screw an go at it like NAVID OG says - force it in there
Re: (nichols_si)
for insurance sake..get a buddy to help make sure the fit is correct first..then get some 3M 2 side d tape and secure the lip
after ur satisfied with the fit u can then do ur drilling..id not only use metal washer s but also rubber one s to help eliminte any vibration s that my eventually crack the lip
the other alternative if u don t want to use the tape is prep the bumper cover and lip and use a industrial type glue..this ll work good cuz ull get more flush apperance..but be advise d getting the lip off later will be alot more difficult
Re: HELP EG FRONT LIP INSTALL!!! (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote">2 bolts on each side of the lip should do the trick</TD></TR></TABLE>
Umm no....unless you want to run over it while going down the road. Just line the lip up to the bumper and drill the holes.
thanks for advice deepnite
i plan prob was 3m tape , i used other tape prior a few days ago to make sure it was ment to fit on haha cuz it didnt have any bolt holes. i think ill use 3m and then prob go with a drilling procedure - im going to remove my bumper first then take out my air box while im at it .. btw : never removed the bummper before , someone advise a few steps on how to do so?
