Help door dosent open from both sides!
My 4door civic is a 99 lx and dosent open on either sides on the driver side rear when it's locked and unlocked.. What could it be the handle or the lock inside the door..what do I do? Take off the plastic? Thanks
Re: Help door dosent open from both sides!
An lx has power door locks so does the button on the inside of the door pop-up when you unlock it? If so, then a clip broke and a rod fell off on the inside of the door. Probably just need a new clip. If the door lock **** on top of inside door doesn't pop-up when unlocked you have an actuator problem. Either way you'll have to remove the inner door panel. Use a couple of flat blade screwdrivers, start at the bottom and go slow. Good luck
suhteevin
01-06-2009 09:04 PM
